4r70w bogs in low gear - TCCoA Forums
post #1 of 6 (permalink) Old 06-06-2011, 07:04 AM Thread Starter
My 95 tbird will on occasion bog in low gear like trans is in low and park at same time , I can let off the gas and try to go again and it works fine, also if you keep pressing accelerator it will release and go fine but does not always do this some days I will have no problems others every time I take off never know what it will do. Please help.
randwolf is offline
post #2 of 6 (permalink) Old 06-06-2011, 07:58 AM
When you say low gear, you mean numerically low? E.G. you're in 1st or 2nd and it feels like it has no power?
Or is it this - you're in 4th or 3rd, you hit the gas and it doesn't downshift to 1st or 2nd like it should initially. You take your foot off the gas and hit it again then it downshifts, or if you hold it down then it downshifts. If so then this is caused by a bad TPS.
post #3 of 6 (permalink) Old 06-06-2011, 11:13 AM
BUCK's Avatar
Exclamation
bad IAC quite possibly the problem here.
BUCK is offline
post #4 of 6 (permalink) Old 06-07-2011, 07:03 AM Thread Starter
What I mean is in 1st gear from take off car will not move and engine will not rev up, like if the brakes were locked release the throttle and press again and it works fine also from a stop light sometimes works like it should other times you have to depress the throttle almost wide open then it is like letting trans brake off and trans works like it should.
randwolf is offline
post #5 of 6 (permalink) Old 06-07-2011, 09:09 AM
what all have you done to the car as far as maintenance goes? and how long ago?
post #6 of 6 (permalink) Old 06-07-2011, 05:30 PM Thread Starter
Have had the egr valve replaced and changed the tps about 4 years ago other than that just routine maintenance.
randwolf is offline
