Does a transmission sensor cause a Cel? - TCCoA Forums
post #1 of 2 (permalink) Old 07-24-2011, 02:39 PM Thread Starter
If I am correct the transmission has a speed sensor and a Control solenoid. Do either of these cause a Cel if they fail?
Crynosis is offline
post #2 of 2 (permalink) Old 07-25-2011, 02:50 PM
There are a number of electronic sensors and solenoids that can set a code, yes. Some of them will also cause the OD light to blink. Not all of these codes are readable with all OBD-II scanners.
VSS, OSS, shift solenoids, temp sensor, TCC, etc; these malfunctioning can cause a CEL and/or blinking OD light.
Bangster is offline
