Mach 1 Auto Trans - TCCoA Forums
post #1 of 7 (permalink) Old 08-01-2011, 04:45 PM Thread Starter
Tx_Cat's Avatar
Mach 1 Auto Trans
Correct me if I am wrong. The trans that came out of the '04 Mach 1 (autos) are 4r75w, correct? Would it be a direct fit to our cars? Any difference between the mac 1 and gt?!
Found a good deal on a mach 1 trans. 38k miles for $500...
Tx_Cat is offline
post #2 of 7 (permalink) Old 08-01-2011, 06:00 PM
Alan can make it work for you, but no, it's not a direct swap.
The easy thing is the tailshaft doesn't have a gear on it for the vss; there are other reasons, iirc.
Grog6 is online now
post #3 of 7 (permalink) Old 08-01-2011, 08:59 PM
It will work but must be completely dismantled. The oss count is also wrong which must either be changed or tuned for it.
post #4 of 7 (permalink) Old 08-02-2011, 08:38 AM Thread Starter
Tx_Cat's Avatar
So it would be easier to just get an GT trans then... I still need to send you my old 95 harness Alan. As you can see, still haven't found a trans. You have any trans available???
Tx_Cat is offline
post #5 of 7 (permalink) Old 08-02-2011, 11:58 AM
I will check my cores and see which is best for you I know I have several 01/02 gt transmsisions that need gone through.
post #6 of 7 (permalink) Old 08-02-2011, 12:20 PM Thread Starter
Tx_Cat's Avatar
Alright. Let me know!!
Tx_Cat is offline
post #7 of 7 (permalink) Old 08-02-2011, 01:47 PM
I have about 6 of the 99-02 mustang transmissions. Figure building them with stage 1 forwards stacked to 6 or with the 5.4 wave plate either way you prefer, Standard late model intermediate stack, 3 or 4 plate reverse, and a 7 plate direct. Full modified valvebody and a hardened sun gear. Also will use a spiral retainer or weld the snap ring on the mechanical diode, high carbon overdrive band, sonnax overdrive servo pin and pressure regulator valve on a fully modified valvebody with the late deep pan that comes on these cores, the cost will be $1300 before tccoa member discount. From there you need a converter and freight. I have a 4r75 but they are nearly twice the price.
