Passing gear - TCCoA Forums
post #1 of 5 (permalink) Old 08-19-2011, 08:06 PM Thread Starter
TNT
Passing gear
I have a 96 Cougar 3.8 with aod tranny my problem is when I push the pedal down to shift into passing gear it seems to hesitate a couple of seconds then it will engage rather hard can this be fixed by some sort of cable adjustment?
TNT is offline
post #2 of 5 (permalink) Old 08-19-2011, 08:39 PM
The 96 cougar has a 4r70w not an AOD, I doubt any adjusting of a cable is going to help that hesitation. If it bogs it may be wise to do a voltage sweep and check of the tps and clean the maf.
post #3 of 5 (permalink) Old 08-19-2011, 08:40 PM
You have a 4R70W electronically controlled transmission, not an AOD.
First things first, how is the fluid? Fresh Mercon V, a new filter and the J-mod would be good places to start. And as Chris said, search for threads on testing the TPS.
post #4 of 5 (permalink) Old 08-22-2011, 07:39 PM Thread Starter
TNT
Fixed the problem Saturday morning it was a cable connected to the throttle body had a lot of slack in it, took the slack out and it shifts fine now.
TNT is offline
post #5 of 5 (permalink) Old 08-22-2011, 08:37 PM
pettyfog's Avatar
First we had a mongrel 94, now this.
Would you please take a pic of that linkage setup on the throttle body?
pettyfog is offline
