4r70w shift problem - TCCoA Forums
post #1 of 4 (permalink) Old 09-04-2011, 06:56 PM Thread Starter
4r70w shift problem
I am having a strange problem with my 95 bird. It is slow to shift from 2-3 and 3-4. It does it at any temp. Reverse, 1-2 is fine. I can stand on the brakes in drive and reverse and it doesnt slip. At speeds of 40-45 it has a delay going into 3.....meaning when you think it should shift, it wont till you hit around 48-50. I just bought the car so I don't know when the fluid was changed but it's bright clean with no burnt smell or debris. I don't notice a problem downshifting. The car has 73,000 on the clock with the 4.6l engine. Could this be a sensor problem?
colo66 is offline
post #2 of 4 (permalink) Old 09-05-2011, 07:21 AM
BUCK's Avatar
Lightbulb
Triple Check Fluid level properly per the Manual - Then I'd probably would start with new MLPS.
BUCK is offline
post #3 of 4 (permalink) Old 09-05-2011, 03:22 PM Thread Starter
Thanks for the starting point! I have a 1996 Ford F-150 that a couple of places said they were the same part. If not, I will buy a new one. I will also check to see if I have the correct dip stick.....checked fluid 4 times after a traveling around 20-30 miles in the mountains here, the same "full" level. I didn't mention that there are no codes, O/D light is working but not flashing. I did have a problem with the turn signals not working...like it had a lamp out. Took switch apart and found the grease was hard and dry. Cleaned it up now works fine. I'm inclined to think, judging by the low miles, that this car has sat for sometime. It had only 3,000 miles added since 2004 according to Carfax.
I will keep you posted!
colo66 is offline
post #4 of 4 (permalink) Old 09-05-2011, 07:57 PM
Mgino96tbird46's Avatar
If that's the case, then I'd replace the fluid and fill with Mercon V. Chances are, it may still have the original fluid.
Mgino96tbird46 is offline
