quick question - TCCoA Forums
post #1 of 3 (permalink) Old 10-09-2011, 08:05 AM Thread Starter
jonv392's Avatar
quick question
I just noticed my tranny is way past full on fluid.what if any damage will this cause? What's the best way to drain some without dropping the pan? Thanks
jonv392 is offline
post #2 of 3 (permalink) Old 10-10-2011, 11:39 AM
BUCK's Avatar
Lightbulb
Assuming you are checking Fluid level correctly with Engine running easiest way to remove Fluid is with a Marine Siphon Pump fm Walmart via the Dipstick.
BUCK is offline
post #3 of 3 (permalink) Old 10-12-2011, 09:00 PM
Krazybird13's Avatar
Be sure that you are looking at whether it is on the hot or cold line also..but as said before, check it running and on level ground.
Krazybird13 is offline
