Speedometer reading too fast - TCCoA Forums
post #1 of 8 (permalink) Old 12-05-2011, 02:54 PM Thread Starter
96_SVT-bird's Avatar
OK, I have had a speedcal from Dallas mustang for several years, and had no problems with it. I swapped my 4.10's (open diff) with 3.73's (track lok). This was performed by my local ford dealership. Now, my speedo reads approx 10mph too fast @ 70mph. I have contacted Dallas mustang, and they gave me a new dip switch setup, and its still reading off. Now, I'm wondering if there's something awry in the diff, or possibly a sensor. Any input would be appreciated. ('96 T-bird, 4.6L)
-'96 T-bird, PI heads & intake, Trick flow cams, '02 GT MAF, Mustang K&N FIPK, Accufab TB, C&L Plenum, B&M shift improver, SCT chip by Lonnie, 3.73 Trac Loc, 2.5" True dual exhaust w/ SLP mufflers, 17x9 Cobra R replicas, Eibach pro kit.
-'01 Lightning, 3lb upper pulley, Superchip,K&N cold air intake. 1/4 mile [email protected]
96_SVT-bird is offline
post #2 of 8 (permalink) Old 12-05-2011, 03:03 PM
You really don't need the speedcal for 3.73s. The purple 21 tooth speedo gear works fine. I'd put a new speedo gear in and take the speedcal out of the equation and see where that takes you.
post #3 of 8 (permalink) Old 12-05-2011, 04:52 PM Thread Starter
That might get me pretty close, but I'm also running 255/45r17's, so it would still be off a bit. (not much, I know, but just enough to piss me off.)
post #4 of 8 (permalink) Old 12-05-2011, 05:09 PM
I'm running the same size tires; my speed is off by about 2%. If I'm going 70 according to the speedo, I'm actually going roughly 68.
post #5 of 8 (permalink) Old 12-07-2011, 02:10 PM Thread Starter
well, that's not too bad off. guess I'll give it a shot and see what happens. Thanks.
post #6 of 8 (permalink) Old 12-07-2011, 02:31 PM
Black_Cat's Avatar
Easy fix, check the Electronics area of the forum and look at my writeup on the Speedcal. For your initial PPM use 8000 to eliminate the 2% of error.
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
2008 BMW 535i Premium Sport Package
Black_Cat is offline
post #7 of 8 (permalink) Old 12-20-2011, 01:19 PM Thread Starter
Ripped out the speedcal, installed purple speedo gear, problem solved. Thanks guys!
post #8 of 8 (permalink) Old 12-20-2011, 08:18 PM
want to sell speedcal cheap? pm me.
Grog6 is online now
