1996 TBird, 4R70W Question - TCCoA Forums
post #1 of 40 (permalink) Old 12-27-2011, 10:27 PM Thread Starter
Urambo Tauro's Avatar
1996 Thunderbird, 175000 miles
I recently picked up this TBird, which replaces my old 1994 Cougar 3.8.
On that Cougar, I updated the Fluid to Mercon V (and changed the 1-2 accumulator piston) to counter a shudder that showed up. It worked and the shudder went away.
So now I have this TBird, which has quite a few more miles on it. The previous owner had it serviced about 30,000 miles ago. At that time the filter was changed, the fluid changed to Mercon V, the 1-2 accumulator piston updated, and a B&M shift kit was installed (per setting "1").
I have not noticed any transmission issues with this TBird, so I am doing my best to maintain it. The time came to change the fluid and filter, and I wanted to replace the other (2-3?) accumulator piston while I was under there. I read up on the procedure, which involves removing the valve body, then went at it. Now it's got fresh fluid, fresh filter, new piston, and a drain plug.
Now, when I removed the valve body, I was expecting a gasket on top of it per a video I watched. But nothing was there, and I put it back together the way I found it. Is this a problem?
Urambo Tauro is offline
post #2 of 40 (permalink) Old 12-27-2011, 10:54 PM
There should have been a metal plate between the valve body and the tranny case. On both sides of that metal plate, there should be paper gaskets.
~Rick
TCCoA Sig
post #3 of 40 (permalink) Old 12-27-2011, 11:45 PM
Someone left the gasket off, I worked with a guy who was too stupid to id gaskets and put transmissions together that way. They all came back, but some of them did work halfway decent. I don't sugest it at all but it may or may not work.
post #4 of 40 (permalink) Old 12-27-2011, 11:46 PM
Alan, would make sense to me that you HAVE to be loosing pressure in there somewhere! It HAS to leak between those plates, wouldn't you think?
~Rick
TCCoA Sig
post #5 of 40 (permalink) Old 12-28-2011, 12:56 AM
Unless everything is 100% perfect it has to be leaking. Now if the plate were made of soft material such as copper or brass it might work, but it would only be able to be used once and somethign would have to be done to give the check balls an area to seat.
post #6 of 40 (permalink) Old 12-28-2011, 01:00 AM
That's insane I can't believe someone would do that. They would just intentionally leave it off? And it actually half/donkey worked?
post #7 of 40 (permalink) Old 12-28-2011, 02:20 AM
Yeah, I have only seen one person do it. He was the high volume builder the shop I used to work for hired to replace 3 employees. He could put a transmission together really fast. I used to stay in the evening and R&R transmissions for cash. After doing a 4r55e he built 9 times they decided they couldn't afford to pay me to do it anymore. Everytime it had no reverse and I found the problem for him. he mix matched the center support. I tried to show him what was wrong but he yelled at me and told me I didn't know what I was talking about. I read it from a TSB in the manual in front of him. He went ahead and put the transmission back together his way. When he left for the day the owner and I fixed it. Interesting story this guy was. He made 3 times what anyone else in the shop made but quit because he wanted a raise after only 3 months. They also paid to move him here from Florida. He got better pay from Aamco then overdosed on cocaine about 2 weeks after getting the new job....
I don't suggest doing anything he did.
post #8 of 40 (permalink) Old 12-28-2011, 08:22 AM
..... half/donkey worked?
~Rick
TCCoA Sig
post #9 of 40 (permalink) Old 12-28-2011, 10:26 AM
BUCK's Avatar
Thumbs down
1996 Thunderbird, 175000 miles - Now, when I removed the valve body, I was expecting a gasket on top of it per a video I watched. But nothing was there, and I put it back together the way I found it. Is this a problem?
Problem here is IF your goal was truly to achieve "doing my best to maintain" the Tranny you'd have replaced all the ridiculously INexpensive Gaskets that were disturbed~! - I predict a quick, total & costly Tranny & TC failure.
BUCK is offline
post #10 of 40 (permalink) Old 12-28-2011, 06:47 PM Thread Starter
At the risk of sounding defensive, I really must admit that "my" best does not equal "the" best. That's exactly why I posted this thread, so that "my best" can get better.
Thanks everybody for all the replies. It is clear that the gasket is indeed necessary, not something that should be left out for a specific reason or benefit (like accumulator piston springs). I'm planning to remedy this. Now my next step is to find out just how crucial this is. Do I need to stop driving it ASAP and get this thing right? Can it wait until my next scheduled fluid change? What kind of damage would I be risking by putting it off and how likely is that damage to occur? I have been driving the car as is for about 1000 miles without any noticeable problems.
post #11 of 40 (permalink) Old 12-28-2011, 07:50 PM
SuperNewbie
supergordo's Avatar
I understand trying to get better. Crap happens. Go get a gasket and install it. It's the smart thing to do.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #12 of 40 (permalink) Old 12-28-2011, 09:24 PM
BUCK's Avatar
Lightbulb
At the risk of sounding defensive, I really must admit that "my" best does not equal "the" best. That's exactly why I posted this thread, so that "my best" can get better..
& IMO it's not one bit OFFENSIVE to note that Mechanic 101 dictates you replace an IN-expensive disturbed Gasket.
BUCK is offline
post #13 of 40 (permalink) Old 12-28-2011, 09:49 PM
Dude, it's not gonna blow up. If the pressure gets too low, it will just "slip". If it hasn't done anything like that, you'll be fine. I would recommend you put the gaskets in ASAP (they are pretty cheap at any Ford stealership); yes, you can wait until you do a filter/fluid change. Unless your tranny is noticeably slipping (which means it feels like you put it in Neutral for a second or two or longer when you step on the gas in Drive), you aren't gonna hurt it.
~Rick
TCCoA Sig
post #14 of 40 (permalink) Old 12-28-2011, 10:10 PM
BUCK's Avatar
Thumbs down
I say BS - It will slip & blow up all to Hell.
BUCK is offline
post #15 of 40 (permalink) Old 12-28-2011, 10:21 PM
Yeh, I guess I wasn't very clear because at the beginning I said slipping is OK, then at the end I said slipping isn't ok.
Let me see if I can clear that up.
If it DOES NOT SLIP, you aren't gonna hurt it.
I have a Caravan that I have put over 100,000 miles on that has a leak. I have cleaned the transaxle, replaced gaskets and seals, but it looks like it leaks around some "test ports" that are built into the front. When the fluid gets low enough, it will slip. I simply add fluid and keep going; it's been doing this since I've owned it which is over two years.
I also know someone who has a Malibu that has an INTERNAL leak like we are talking here. Let me tell you what happens to his car. It will NOT take off from a stop unless you put the car in 1st gear manually (as opposed to leaving it in Drive). He couldn't fix it and I diagnosed and didn't exactly fix it, but made it driveable without having to go down to 1st every time you stop. On this particular car it still has a vacuum modulator which doesn't control shifting (computer does that), but does control the pressure in the tranny. How it works it less vacuum (as in pushing harder on accelerator), the higher the pressure. So just disconnect the vacuum line and run it like that. The tranny will run at full pressure (which isn't a big deal in this case since it's leaking internally anyways). He's been driving it over a year like that. Yes, he should tear the tranny apart and fix it right, but it's an old car and he really doesn't want to.
Point being - if his tranny isn't slipping, he isn't gonna "blow it up all to hell".
~Rick
TCCoA Sig
post #16 of 40 (permalink) Old 12-30-2011, 07:22 PM Thread Starter
Nothing's slipping right now, but I'm going to get this done on the "soon" side of eventually. I put in a drain plug, so I really don't have much of an excuse to put it off. I'll save the fluid in clean jugs to put back in once I'm done. Thanks again!
post #17 of 40 (permalink) Old 12-30-2011, 08:43 PM
BUCK's Avatar
Thumbs down
No hurry... the POS Roller Clutch in your POS 96 Tranny will die any day now so just have $1k - $2K handy.
BUCK is offline
post #18 of 40 (permalink) Old 12-30-2011, 11:24 PM
Dang Buck, you're just a hodgepodge of great news, aren't you? Happy New Year to you, too and lay off the spiked Egg Nog, will ya?
Talking about roller clutch, I have a weird issue that shows itself once or twice a month. Sometimes when I'm "gettin' on it" with the TBird, when it shifts from 1st to 2nd, it like "Neutrals out" and revs up with funny rattling sounds out of the tranny like shaking ball bearings in a can. I instinctively let up on the throttle and it will eventually catch 2nd.
When I posted that weird issue here on TCCoA, a few responded with roller clutch going bad. It's actually the girlfriend's car, so she never has a problem (she doesn't drive it hard). If a young male owned our Thunderbird, the tranny would probably be blown up by now, we just don't abuse it much (well, one of us doesn't - lol)! It does seem to go through rear tires A LOT quicker than front ones
~Rick
TCCoA Sig
post #19 of 40 (permalink) Old 12-30-2011, 11:30 PM
dDUBb's Avatar
The Intermediate clutch applies in 2nd gear which is what locks the roller clutch and the Reverse drum to the transmission case .. so slipping during the 1-2 shift could certainly end with a big bang.
Could be a hydraulic pressure loss during the 1-2 shift .. bad or mis-aligned MLPS. I have swapped in 8 tooth output shaft transmissions and with the "correct" speedo gear, it would not shift into 2nd before the engine's rev limiter hit on a WOT run, but when I J-modded the valve body and opened up the 1-2 shift a little more it was good to go. If you dont have enough fluid pressure you will slip and I have heard this many times on a 1-2 WOT where they let up on the gas before the shift ..
And I agree it's just bad to go around telling everybody their transmission is a POS and it will die any day now, blah blah blah .. cmon Buck, my father died at 43 years old, youre well past his age .. please tell me youre not living on borrowed time, but rather you took care of yourself instead of saving up the $$ to upgrade the internals ...
dDUBb is offline
post #20 of 40 (permalink) Old 12-30-2011, 11:33 PM
That's EXACTLY how it's acting! If I hold it WOT, that doesn't happen, it only seems to happen if I let up on the throttle a little.
~Rick
TCCoA Sig
post #21 of 40 (permalink) Old 12-30-2011, 11:43 PM
The transmissions in these cars were great transmissions once updated, but none of them came updated. They all fail sooner or later and they are all old!
post #22 of 40 (permalink) Old 12-31-2011, 02:33 AM
BUCK's Avatar
Thumbs down
Talking about roller clutch, I have a weird issue that shows itself once or twice a month. Sometimes when I'm "gettin' on it" with the TBird, when it shifts from 1st to 2nd, it like "Neutrals out" and revs up with funny rattling sounds out of the tranny like shaking ball bearings in a can. I instinctively let up on the throttle and it will eventually catch 2nd.:
POS Roller Clutch in your GF"S POS Tranny will die any day now so just have $1k - $2K handy.
BUCK is offline
post #23 of 40 (permalink) Old 12-31-2011, 10:42 AM
Nice, it's been doing that for over 2 years. I will keep your advice in mind. I found SCTbird1994's posts a little more informative.
Since I've seen you post this repeatedly, I'm guessing you blew the sh*t out of your tranny and are now just a little bitter?
I also own a 1995 Mark VIII LSC that shifts like a charm! No issues whatsoever and tranny's stock (for now); it even barks the tires when I get on it!
I've actually owned the Thunderbird for about 6 years, but sold it to her 2 years ago (never got paid, of course; I never do when it comes to girlfriends).....
~Rick
TCCoA Sig
post #24 of 40 (permalink) Old 12-31-2011, 10:59 AM
96PRLBRD's Avatar
BUCK was telling me how my tranny was POS and was going to blow up too. He must have a bad tranny experience because most of his posts are about these POS trannies.
--> My most recent pics <--
96PRLBRD is offline
post #25 of 40 (permalink) Old 12-31-2011, 11:06 AM
Yeh, following that logic - I've had a bad experience with a girlfriend before therefore they all suck!
Ok, maybe that's a bad analogy....
~Rick
TCCoA Sig
post #26 of 40 (permalink) Old 12-31-2011, 11:10 AM
Say what you want guys but there is no doubt if you race or drive hard on a 7 element roller clutch it's days are few. I have managed to keep a 14 roller alive a while but eventually it broke as well. I have seen plenty of broken diodes too.
post #27 of 40 (permalink) Old 12-31-2011, 11:13 AM
Mgino96tbird46's Avatar
I was told by a well known 4r70w builder that my one way roller clutch can take up to 6000 RPM. Torque converter can take more than 5400 RPM also. My car is tuned to shift at 5600 RPM. I was told this is safe. Probably due to my close to stock power level.
Mgino96tbird46 is offline
post #28 of 40 (permalink) Old 12-31-2011, 11:15 AM
I'm older than you, Alan, and what I can positively tell you is if you beat on anything long enough - something breaks. The more power you make, the quicker that happens. Seen it happen hundreds of times over the years.
So I'm not doubting that what Buck is saying is true - it WILL break. It's her daily driver and NEVER gets abused by her and most likely won't ever break if she was the only one driving it. If I used it for just a play car (which I did for a couple years prior), I wouldn't give it another year.
Maybe that's what will happen with the LSC because it's not a DD, it's just a nice project for me and it gets abused, I'll be the first to admit it. Like you pointed out, it's a 14 roller so hopefully by the time it does give up the ghost, I'll have already started my tranny build.
~Rick
TCCoA Sig
post #29 of 40 (permalink) Old 12-31-2011, 11:22 AM
BTW, which 4r70w's came with a 14 element roller clutch?
post #30 of 40 (permalink) Old 12-31-2011, 11:27 AM
I think only the Mark VIII's because of the higher output 32v engine.
By the time the Marauder came out, they were all mechanical diode.
~Rick
TCCoA Sig
