fluid change procedure - TCCoA Forums
post #1 of 14 (permalink) Old 02-05-2012, 09:29 AM Thread Starter
tehsilver95lx's Avatar
I get the gist of unbolting the pan and draining the fluid,but where do i refill it? through the fluid check tube? and what would be the best fluid to replace the old stuff with?
Beater lx,current mods: cold air,drilled and slotted rotors,glass pack muffler. Scrapped
Teal terror 94...trans slip and a fram air hog filter!
94 Sc :Cobra R hood,96-97 Front lights,3.73 Trac Lok,1" Raised top,5% OD Blower Pulley,CAI,Removed resonator,Gutted cats,No mufflers. "It roams around in a open loop speed density tune. killing small children and raping helpless mothers at night."
....THAT DOES NOT MATTER!....
tehsilver95lx is offline
post #2 of 14 (permalink) Old 02-05-2012, 10:03 AM
Yes refill with the check tube, Also use a name brand of fluid with mercon 5 . The chief has Wynn's in my bird .
post #3 of 14 (permalink) Old 02-05-2012, 10:32 AM
96PRLBRD's Avatar
Ideally you want Motorcraft Mercon V, that is the best fluid.
--> My most recent pics <--
96PRLBRD is offline
post #4 of 14 (permalink) Old 02-05-2012, 07:28 PM
I like the Wynn's robert gets and the Wolfshead I buy best. Both are full synthetic. Motorcraft is semi synthetic and a good choice.
post #5 of 14 (permalink) Old 02-05-2012, 08:08 PM
Ahh Cool Alan.... My grandfather used WHs motor oil his whole life in his farm equipment and autos, I have always asked around and no one had ever heard of it , Nice to see that you have
post #6 of 14 (permalink) Old 02-06-2012, 11:27 AM
BUCK's Avatar
Exclamation
Many & more complete Threads on this - If you are refilling it while on Car Ramps remember to NOT Refill it all the way while on Ramps ~! - Leave it at least a Quart or 2 low on Ramps - Back the car off & level it THEN Fill all the way - If you get it even ALMOST Full while on Ramps you will get a HELL of mess EVERYWHERE as it overflows out the Vent on top rear of Tranny... been there... done that... drank the red Koolaid... TRUST me you'll only screw that up ONCE~!
BUCK is offline
post #7 of 14 (permalink) Old 02-07-2012, 01:07 PM Thread Starter
im going to have a lift,how much fluid is a full pan? on level ground?
post #8 of 14 (permalink) Old 02-07-2012, 04:27 PM
Mgino96tbird46's Avatar
How about Castrol Mercon V? Is it decent?
Mgino96tbird46 is offline
post #9 of 14 (permalink) Old 02-07-2012, 04:33 PM
I consider it in 4th place.
post #10 of 14 (permalink) Old 02-07-2012, 04:46 PM
I believe 13 qts ,That includes the TC.
post #11 of 14 (permalink) Old 02-07-2012, 05:18 PM Thread Starter
to fill the pan is 13qts? im in an automotive technology course for 11Th grade and my teacher is a ford senior master technician and he said it'd be like 6 or 7 quarts so for the pan its still 13 qts?
post #12 of 14 (permalink) Old 02-07-2012, 05:53 PM
The entire transmission holds 13 qts with converter, Without droppign the valvebody or removing the filter the pan itself holds about 4.5-5 qts. If you remove the filter add at least a quart, more if it was off for a long time. If you drop the valvebody you'll drain most of the converter as well and it will take about 9-10 qts. If you drain the converter, drop the valvebody and let it drain completely you'll have 13 qts in it.
post #13 of 14 (permalink) Old 02-07-2012, 06:43 PM Thread Starter
so if i droped the pan 5 qts? would that cure my slipping when i take corners fast?
post #14 of 14 (permalink) Old 02-07-2012, 06:48 PM
No, but upgrading to the deep sump pan and filter most likely would...
