Trans issue 95 Cougar V8 - TCCoA Forums
post #1 of 15 (permalink) Old 02-11-2012, 04:20 AM Thread Starter
Hi,
I have a friend who has a 1995 Cougar with the V8.. They are telling me it is having a trans issue when it is cold. They are describing it like it might be starting to slip. I have not felt it happen the very few times Ive driven it cold. I don't think its had a fluid flush in quite awhile. I'd like to take it in and get a full flush done but am hesitating slightly, remembering all the old horror stories of once you flush it, it may grenade itself.
The car does have a EGR No flow code and a O2 sensor code that Im in process of finding a warm spot to dig into fixing it. I'm not sure if either of those could produce any similar symptoms.
Where is the best place to start??
Quasar3210 is offline
post #2 of 15 (permalink) Old 02-11-2012, 05:24 AM
Drop the pan and change the fluid and filter. Might think about switching over to the 96+ style and and filter if he wants to spend the money.
How many miles on the car and how long ago was the fluid done?
post #3 of 15 (permalink) Old 02-11-2012, 05:28 AM Thread Starter
Honestly, no clue on either question.
Odometer stopped turning a long time ago. I am honestly not sure if its been changed since they owned it. 2008 or so.
post #4 of 15 (permalink) Old 02-11-2012, 05:33 AM
I would skip the flush and drop the pan and change the fluid and filter. The flush might turn into one of those horror stories you mentioned!
post #5 of 15 (permalink) Old 02-11-2012, 06:03 AM Thread Starter
Gotcha.
I think Ill start there. Maybe a can of the Seafoam trans tune in with it. and maybe change the filter and fluid again in 6 months.
It definitely only acts funny when its stone cold. Drives totally fine once warmed up.
post #6 of 15 (permalink) Old 02-11-2012, 09:14 AM
That sounds like a worn pump to me, I have a van that does that and I've seen it in the past.
Let us know if the fluid/filter change helps!
~Rick
TCCoA Sig
post #7 of 15 (permalink) Old 02-11-2012, 09:27 AM
Change to the deep sump pan and filter. My Cougar did the same thing until I went with the newer pan. Fluid starvation is the cause.
post #8 of 15 (permalink) Old 02-13-2012, 01:24 AM Thread Starter
Where would I order a deep sump pan from?? Do you think that would fix the issue completely. Kind of on a tight budget on this one. Figure If i am gonna drop the pan for a fluid/filter change anyway. It can't hurt if the pan is reasonably priced.
post #9 of 15 (permalink) Old 02-13-2012, 01:42 AM
1996 or newer 4R70w/4R75w equipped cars, it's identifiable by the bump at the center.
post #10 of 15 (permalink) Old 02-13-2012, 07:02 AM
New from Ford the pan and filter are less than $50 together.
post #11 of 15 (permalink) Old 02-13-2012, 10:51 PM
I can usually get used pans pretty cheap and the filter I get cheap too. As long as I can get one I can get both shipped to you for that. Ford is strange one day you order somethign and it is $35 the next day it is $90 and a few months later it is $20. Sometimes Ford prices are impossible to beat.
post #12 of 15 (permalink) Old 02-13-2012, 10:57 PM
Ford dealership in Perry, Florida charges 69.00 for a 4 wheel alignment. Every other place charges close to $100 around here.
~Rick
TCCoA Sig
post #13 of 15 (permalink) Old 02-21-2012, 07:07 PM Thread Starter
Hi all,
I've yet to get a chance and experience this problem for myself, Alan, as soon as I figure out my course of action, I will let you know on that pan and filter.
Could a No Flow EGR code, possibly make the car chug or feel anything like a trans slipping a little??? Im dealing with a very rough description of the problem but I know what codes came up on my scanner.
post #14 of 15 (permalink) Old 02-21-2012, 07:27 PM
Yes that can happen.
Usually they buck and surge.
post #15 of 15 (permalink) Old 02-21-2012, 10:13 PM Thread Starter
Thank you Alan,
This makes me wonder because it was decribed as a bucking feeling, much worse when the car is cold... I gotta rip that EGR apart ASAP.
