transmission cooler - TCCoA Forums
post #1 of 57 (permalink) Old 02-23-2012, 09:29 PM Thread Starter
transmission cooler
Guys is this a good deal? and will this fit right? and will this get the job done i have a jmod from RobertP still have a spring for 1-2 and have a tune from don Lasota @ Lasota Racing. any info will be great.
and i can get it for 22.99
Thank you
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Econo-Kool&174;-Transmission-Oil-Cooler-Imperial_6015018-P_895_R|GRPCOOLAMS_____
1997 Thunderbird 4.6L
New paint on tops, Magnaflow high flow cat system and custom 2 - 2 1/2 Exhaust ,J-Mod and P.I. head and intake swap(performed by RobertP @ www.RobsTireAndAuto.com ) Steeda Underdrive Pulleys, Mark VIII TC, AEM dry flow air filter, Blacked out tail lights and custom painted headlights (performed by my wife) tuned by DON at http://www.lasotaracing.com/
waiting to hear theses kooks
http://www.cardomain.com/ride/391835...rd-lx-coupe-2d
swampt420 is offline
post #2 of 57 (permalink) Old 02-23-2012, 09:32 PM
I think Robert is running a special on coolers I believe.
http://forums.tccoa.com/showthread.php?t=138396
post #3 of 57 (permalink) Old 02-23-2012, 09:52 PM
Thank you
FWIW, I put a Cobra radiator in my Thunderbird (which doesn't have a tranny cooler) and I used that exact cooler on the front for the trans cooler.
Good news: it works
Bad news: the trans temp runs like 200* on hot days which I know is too high - I'll get the big 45K btu cooler beast that Robert sells when I get the funds!
~Rick
TCCoA Sig
post #4 of 57 (permalink) Old 02-23-2012, 09:53 PM
Too small in my opinion. Then again I am running the tru-cool 45,000 btu transmission cooler. However the kit robertp is selling would probably be sufficient if your bird is stock.
post #5 of 57 (permalink) Old 02-24-2012, 12:04 AM
95LX4.6's Avatar
The kit that Robert P. sells is 45k IIRC. So it would be sufficient waaaay past stock too.
95LX4.6 is offline
post #6 of 57 (permalink) Old 02-24-2012, 12:20 AM
The 45k btu cooler is 8 1/2 x 22 3/4 x 1 1/4 inch.... the kit Robertp has for sale is 11 x 11 3/4 x 3/4 inch, my guess is it's rated closer to 20k btu
post #7 of 57 (permalink) Old 02-24-2012, 01:45 AM
Wouldnt you say a fan is needed on the 45k cooler if youre in NV or AZ, NM, or TX.
I know that cooler just radiates the heat on the summer where I think it might be too hot for the trans.
On the other hand running hot is a tbird tradition LOL.
post #8 of 57 (permalink) Old 02-24-2012, 01:47 AM
I don't have a temp gauge for the trans yet, so it's hard to tell, but I am working on a fan system for mine.
post #9 of 57 (permalink) Old 02-24-2012, 07:01 AM
95LX4.6's Avatar
Link to Robert's 45k trans cooler on his website.
http://www.robstireandauto.com/products.html
Here is a pic of it mounted on TM's car that is pushing 390RWHP IIRC with a SVO blower.
http://www.robstireandauto.com/image...rInstalled.jpg
Should be fine for just about any amount of power your after imo.
95LX4.6 is offline
post #10 of 57 (permalink) Old 02-24-2012, 08:06 AM Thread Starter
well i do want one of RobertP's but can't afford it right now. i seen this one for 22.99 i figure i should get this one until i can get RobertP's. i do have the jmod and a tune and it does shift firm. so should i get it to hold me over or just wait about 2 months to get the other.
post #11 of 57 (permalink) Old 02-24-2012, 09:28 AM
Mgino96tbird46's Avatar
That's the cooler he recommended for my setup. It is supposedly rated for a motor home towing 10,000 lbs. I'd say that's enough for me. lol
Mgino96tbird46 is offline
post #12 of 57 (permalink) Old 02-24-2012, 09:42 AM
Darrin's Avatar
For an extreme budget, here, this.
http://www.amazon.com/Hayden-Automot.../dp/B000C39CL8
What the OP posted is a fin and tube cooler. Way less than optimal.
For those who are curious, on the 45k coolers you don't need a fan.
Darrin is offline
post #13 of 57 (permalink) Old 02-24-2012, 10:39 AM
BUCK's Avatar
Lightbulb
- I went with a brand new Ford P/N F4TH 7A095 for $25 off EBAY - Optional Trans Cooler on the old Windstars but the Ford P/N has a nice bracket well suited to under Bumper installs on Mk's & Tbirds although it was probably in front of Rad stock (which I would NEVER do) - It's just a $60 B&M 70273 with a bracket - Compression fittings on existing lines cut at Passenger side & Hose Barb adapters to a short run of $3 a foot dude Hi Press line - & Yes this is one of the things you can shop to death on EBAY once you know what size & thickness your desired location will handle.
- I say delete the Rad Cooler PERIOD - You do NOT want to end up like the dudes who have seen our Plastic ended Aluminum Cored Rads fail - It AINT pretty - I've seen some favorable changes in how my VCRM kicks in the Fan since I deleted the Tranny heat load fm Rad - Up North you'll need some kinda Fluid Temp Sensing Valve.
BUCK is offline
post #14 of 57 (permalink) Old 02-24-2012, 01:52 PM
Failure to read post 2.
We are referring to the kit he has on sale. Not the 45k kit. I am aware that he sells both. Also for what it's worth, he isn't the only source for a tru-cool 4739-1 45k btu cooler. We were recommending an affordable slightly larger cooler to the OP rather then the smaller tube and fin unit he found, however the 45k unit is probably the best solution for a modified car, if the OP's car is slightly modified or not modified at all, running the cooler posted in the link that robert has on sale would be more then sufficient.
You completely misunderstood the difference between the cooler he has on sale here
and the cooler he has for sale on his website.
Also yes I am very familiar with the 45k cooler on his website, that ThunderChecken and TrunkMonkey, are using, I'm running the same unit on my car.
You can see the cooler in the picture behind my crash bumper.
post #15 of 57 (permalink) Old 02-24-2012, 02:00 PM
With no stall converter I'm sure that unit will be sufficient on your set up, however if you plan on upgrading the TC I'd go with the larger one, that way you don't have to spend money twice.
post #16 of 57 (permalink) Old 02-24-2012, 02:04 PM
Agreed, still a much better choice then the sub par tube and fin.
post #17 of 57 (permalink) Old 02-24-2012, 02:09 PM Thread Starter
so you guys just do away with the radiator all together? i was under the impression that you just tied it in. with the plate style that darrin suggested would i tie it in or do away with it?
post #18 of 57 (permalink) Old 02-24-2012, 02:11 PM
Tied in, also fwiw my 45k unit is tied in. I didn't bypass my radiator.
post #19 of 57 (permalink) Old 02-24-2012, 02:14 PM Thread Starter
thank you, when and if i add this cooler how much fluid do i put in
post #20 of 57 (permalink) Old 02-24-2012, 02:15 PM
I think Robert did the same on mine, I understand it helps get the fluid up to temp on cold starts
post #21 of 57 (permalink) Old 02-24-2012, 02:18 PM
Hate to sound like a jerk, but whatever it takes to bring it up to the appropriate full cold or full hot mark on the dipstick.
An extra qt maybe? Buy 2 to be safe?
post #22 of 57 (permalink) Old 02-24-2012, 02:23 PM
That's what I was told too.
post #23 of 57 (permalink) Old 02-24-2012, 02:44 PM Thread Starter
you don't sound like a jerk at all thank you. and its people like all of you that make me proud to be part of tccoa. thank you to everybody
post #24 of 57 (permalink) Old 02-24-2012, 03:31 PM
Glad to help, If I recall correctly my car took something like 16 qts expensive. Then again my transmission was completely empty, so that's what it took to fill the system with the 45k cooler, LPW deep sump transmission pan, lines, converter, transmission itself, etc... But if all your doing is disconnecting the line from the rad, splicing in a small cooler, and needing to top it off I doubt it would take more then 1qt. I just say get 2qts to be safe, better to have too much on hand then having to go back out to the parts store to get more fluid to top it off.
post #25 of 57 (permalink) Old 02-24-2012, 04:00 PM
Robert and I are installing a Mark VIII converter here in under two weeks. That's the most I'm going to be running for a few years as I am a relatively broke college student. I won't get a serious Dirty Dog converter until I have some real money rolling in.
post #26 of 57 (permalink) Old 02-24-2012, 05:09 PM
The 679 cooler is more than what most need that's a huge cooler, the 45k is just over kill, unless your road racing, that's the o ly reason my car even has that cooler
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #27 of 57 (permalink) Old 02-24-2012, 05:23 PM
115+ summers and aggressive canyon carving, that's why mine has one.
post #28 of 57 (permalink) Old 02-24-2012, 10:12 PM
Try 100-120 degrees during the day sitting in traffic stop and go style for a while. And if not stuck in traffic Im likely driving a little aggressive, mostly because thats how AZ wants you to drive.
I cant wait to see what you come up with for the fan set up. Ill be no doubt doing one myself. I hope the lines from DD stop it from getting hot enough to do any damage just by regular driving everyday come summer time.
post #29 of 57 (permalink) Old 02-24-2012, 10:29 PM
When I finally get around to doing it I'll be sure to post many pictures of the set up as well as detailed information on what I used.
post #30 of 57 (permalink) Old 02-24-2012, 11:28 PM
N8tiveJuggalo17's Avatar
I got a cooler from DD similar to the 679 i believe with his aluminum cooler lines. IIRC he made me the lines and bypassed the radiator all together. He said it would be good for the south dakota enviroment of below zero winter temps to over 100 summer temps. I will be moving to AZ this summer tho so maybe itll work out.
---Jeremy
N8tiveJuggalo17 is offline
