something funny going on - TCCoA Forums
post #1 of 28 (permalink) Old 03-19-2012, 09:36 AM Thread Starter
ok so today when i was in stop and go traffic i put the car in second to keep from constantly shifting from 1 to 2. so when i started to move forward the car started to vibrate until i hit maybe 7-10 mph. what do you guys think this could be?
1997 Thunderbird 4.6L
New paint on tops, Magnaflow high flow cat system and custom 2 - 2 1/2 Exhaust ,J-Mod and P.I. head and intake swap(performed by RobertP @ www.RobsTireAndAuto.com ) Steeda Underdrive Pulleys, Mark VIII TC, AEM dry flow air filter, Blacked out tail lights and custom painted headlights (performed by my wife) tuned by DON at http://www.lasotaracing.com/
waiting to hear theses kooks
http://www.cardomain.com/ride/391835...rd-lx-coupe-2d
swampt420 is offline
post #2 of 28 (permalink) Old 03-19-2012, 09:53 AM
renello79's Avatar
Maybe a motor mount? I could be wrong but I would look at those first
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #3 of 28 (permalink) Old 03-19-2012, 11:37 AM
Probably the torque converter shuttering. Why are you manually shifting your auto? What else is wrong with the car?
onelapduster is offline
post #4 of 28 (permalink) Old 03-19-2012, 12:20 PM Thread Starter
nothing wrong at all just hate having to make 7 or 8 shifts when i can just keep it in 2nd. just my thinking but figured that keeping it from shifting more than it has to might help with wear and tear. I've gotten the jmod and a tune. another thing is that it doesn't do it all the time
post #5 of 28 (permalink) Old 03-19-2012, 07:49 PM
+1 My guess from available info is torque converter shutter, too.
~Rick
TCCoA Sig
post #6 of 28 (permalink) Old 03-19-2012, 08:18 PM
My thought is also torque converter shudder.
BTW (I may be mistaken) but I think I read a few times that keeping the car in manual 2nd all the time isn't a good idea because of something related to higher than normal line pressures.
post #7 of 28 (permalink) Old 03-19-2012, 08:24 PM
Well, it's only common sense, taking off in 2nd all the time HAS to be harder on the tranny than 1st. Definitely more heat being generated by the torque converter since it is so hard to spin the tranny input shaft.
I'm just sayin'.....
~Rick
TCCoA Sig
post #8 of 28 (permalink) Old 03-19-2012, 09:38 PM Thread Starter
thanks for the info, i will stop keeping it in 2nd. but i have another question, the tune that i received from don makes first gear want to rev high before shifting sometimes. would it be all right to shift into 2nd from drive to make the shift sooner? and the car doesn't vibrate all the time actually only felt it twice in probley a months time and both times i was in 2nd should i be looking for a new TC or just keep an eye out for the car acting funny.
post #9 of 28 (permalink) Old 03-19-2012, 10:19 PM
Before I would start shopping for anything, I would get your car on a lift and look for something loose - ds bolts, tailshaft housing, u-joints, cv joints, suspension bushings, converter nuts, etc.
~Rick
TCCoA Sig
post #10 of 28 (permalink) Old 03-19-2012, 10:42 PM Thread Starter
dont have a lift but do have some ramp so i will look at tomorrow thanks for the advice. ill post what i find tomorrow
post #11 of 28 (permalink) Old 03-20-2012, 06:16 AM
I'd drop him an e-mail and ask if he can lower the low throttle shift points so it feels more 'stock' at light throttles, but stays in performance mode when you get on it.
post #12 of 28 (permalink) Old 03-20-2012, 08:03 AM Thread Starter
if the tc is going bad could that cause ur car to stall when coming to a stop.
post #13 of 28 (permalink) Old 03-20-2012, 08:24 AM
I have seen that happen, but on a GM, not a Ford.
~Rick
TCCoA Sig
post #14 of 28 (permalink) Old 03-20-2012, 08:48 AM Thread Starter
is there any way to test ur iac value
post #15 of 28 (permalink) Old 03-20-2012, 08:58 AM Thread Starter
this is basically what has been happening. if i give the car some gas it wants to die when i come to a stop. if i drive average its fine.
post #16 of 28 (permalink) Old 03-20-2012, 12:19 PM
I believe when you manually shift to 2nd it clamps the OD band down on the drum. The vib could be the OD band slipping and is probably toast. How many miles on the trans?
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #17 of 28 (permalink) Old 03-20-2012, 12:48 PM Thread Starter
170,000 but about 70,000 is highway miles. i just started manually shifting not even 2months ago.
post #18 of 28 (permalink) Old 03-20-2012, 02:05 PM
More than likely the roller clutch is not holding and when it releases you are left in 1st gear, when it holds you get second. I don't know why so many people wnat to manually shift this transmission. If it doesn't shift the way ou want it to talk to a tuner, manual selection is only useful for holding range, not correcting shift patterns. For example in trucks when towing going down a big hill with a curve using manual second is easier on the truck than riding the brakes for all they are worth.
post #19 of 28 (permalink) Old 03-20-2012, 02:36 PM Thread Starter
thank you for info DD. do u think this is what's causing the car to stall sometimes?
post #20 of 28 (permalink) Old 03-20-2012, 03:02 PM
The only time I have seen a converter and or transmission cause a car to stall is if it was destroyed.
post #21 of 28 (permalink) Old 03-20-2012, 03:24 PM Thread Starter
well mine diffently isn't destroyed and has only made the vibration twice in a months time. im going to read up more on the search forms about the TC and shoot don a email about the shifting when i get off work, if i knew that it was so bad to manual shift i would have talked to him alot earlier about it. and as far as the whole stalling thing goes im going to clean the maf and since ive already cleaned the iacv im going to replace it. and see if that fixes the problem.
post #22 of 28 (permalink) Old 03-21-2012, 08:03 AM Thread Starter
so i replaced the idle air control value and cleaned the maf but it didn't fix it.after i drove it for about 28 miles then it tried to cut off at a stop sign. and i noticed to day that if your just barley moving with your foot off the brake and no gas it jerks back and forth not neck snapping but diffently noticeable.
post #23 of 28 (permalink) Old 03-21-2012, 08:05 AM
Does it run normally otherwise? Try driving it with the MAF unplugged. If the circuitry inside the MAF sensor is on its way out, no amount of cleaning will fix it.
post #24 of 28 (permalink) Old 03-21-2012, 09:19 AM Thread Starter
yeah it drives perfect if ur not idling. ill drive around the parking lot when im on break. thanks for the info
post #25 of 28 (permalink) Old 03-21-2012, 09:23 AM Thread Starter
question what exactly am i looking for when the maf is unpluged?
post #26 of 28 (permalink) Old 03-21-2012, 09:55 AM
95LX4.6's Avatar
If the engine runs better with the MAF unplugged it either needs to be cleaned or replaced, if no change other than the fact you will throw a code for it being unplugged... then your looking elsewhere for the problem.
95LX4.6 is offline
post #27 of 28 (permalink) Old 03-21-2012, 12:38 PM Thread Starter
ok guys i unplugged the maf and it did idle a little bit better but you cant drive the car at all with it unplugged. it coast a hell of alot better but as soon as you touch the gas peddle it starts booging and wants to shut off. but it does idle a little better.
post #28 of 28 (permalink) Old 03-21-2012, 01:47 PM
95LX4.6's Avatar
Probably needs a really good cleaning imo. Get a can of MAF sensor cleaner and your good to go. Should solve your problem.
95LX4.6 is offline
