Hitting rev limiter - TCCoA Forums
post #1 of 17 (permalink) Old 03-24-2012, 11:18 PM Thread Starter
Earl's Avatar
Hitting rev limiter
First off, I understand that it is not good for the transmission to shift into OD under full throttle...with that said,
I had something strange happen today, I was cruising along, about 45 MPH, decided to have a little fun, pedal to the floor, accelerated to around 80 or so, and hit the rev limiter. This has never happened before, usually it will shift into overdrive/4th gear...I didn't have any flashing OD light or anything like that, and I backed off as soon as this happened. Any ideas?
Earl is offline
post #2 of 17 (permalink) Old 03-24-2012, 11:47 PM
You need to put more garbage in your flux capacitor. Get the Mr. Fusion mod.
post #3 of 17 (permalink) Old 03-25-2012, 12:04 AM Thread Starter
Earl's Avatar
shouldn't I get some dilithium crystals to properly prepare for the flux capacitor mod?
Earl is offline
post #4 of 17 (permalink) Old 03-25-2012, 12:15 AM
No, that's a seperate mod. You'll need nacells to run the power from the crystals to.
I'm telling you, do it old school with a lightning rod or step up to Mr. Fusion for the flux capacitor. Before you ask, no, my Energizer bunny isn't for sale.
post #5 of 17 (permalink) Old 03-25-2012, 01:24 AM
cobra R Thunderbird's Avatar
Just get a hamster wheel, a young highly energetic hampster, and problem solved
2001 GT BULLITT #00762 stock
post #6 of 17 (permalink) Old 03-25-2012, 06:56 AM
What are your mods again? Do you have gears or a tune? Jmod?
post #7 of 17 (permalink) Old 03-25-2012, 09:06 AM Thread Starter
Earl's Avatar
3.73 limited slip, jmod, tune from lonnie, it should be shifting into 4th around 90, not hitting the rev limiter at 80
Earl is offline
post #8 of 17 (permalink) Old 03-25-2012, 11:59 AM
Well if you were in 3rd and at WOT, Lonnie likely had the tune set so it wouldn't shift into OD until you let off the gas.
But at 80 MPH... assuming a locked converter in 3rd, you should only be turning 3700 or so RPM with a near-stock height tire. In 2nd at 80 you'd be more in the range of to 5800-6200 in 2nd unlocked.
If you have ODA capability on the XCal2 I'd suggest lowering the 2-3 shift point by a couple MPH. I had the same issue; I hit the rev limiter once on a 2-3 (with my 3.27s), then dropped the 2-3 MPH by 3 and I didn't have the issue again.
post #9 of 17 (permalink) Old 03-25-2012, 12:23 PM
If you have a stock transmission, I think this is a sign of a problem coming; I have been searching, but haven't found the thread.
My problem seems like it's something slipping when it tries a high-throttle-setting 3-4 shift; I've had this happen on the tbird, which is 97 stock(, and has other issues).
The later trannys will neutral for a sec if you do the 3-4 with low throttle; I changed the shift points and other settings to make that go away. YMMV.
Grog6 is online now
post #10 of 17 (permalink) Old 03-25-2012, 05:01 PM Thread Starter
Earl's Avatar
YMMV???
my car has a 1997 rebuilt trans which showed signs of having previously had either some internal problems, or some shift kit, potentially improperly installed...at that time, two years ago, trans was stock, it got the most aggressive jmod and valvoline mercon v...it has a stock stall converter which does not have a drain plug.
Honestly, the trans has felt slightly strange for a few months...I do have a (bad?) Habit of manually shifting it, which may be harder on things
Earl is offline
post #11 of 17 (permalink) Old 03-25-2012, 05:45 PM
95LX4.6's Avatar
Depends on if your upshifting or downshifting to whether it is bad or not. Upshifting it is pointless since the computer shifts waaaaay faster than you can (I found this out after doing it on the LX and getting yelled at by Ron ) Downshifting is fine if you are going from 4-2 as per Jerry in his tech article. I would just watch to make sure the RPM is not too high before downshifting. Other than that, I really have no idea why your car is hitting the Limiter.
95LX4.6 is offline
post #12 of 17 (permalink) Old 03-25-2012, 06:08 PM Thread Starter
Earl's Avatar
Well, I am just going to see what happens...really the whole car seems to be going through this "everything is wearing out really fast and all at once" stage lately...I dumped a ton of money into it last fall, had a ton of things fixed, and it still needs a bunch more done, it's just really old with a ton of miles on it, so, I'm not sure what I am going to do...drive it to death and then figure it out from there...
Earl is offline
post #13 of 17 (permalink) Old 04-03-2012, 06:17 PM
For what a car payment on a new car will cost for a year, you can fix and paint the mn12.
Grog6 is online now
post #14 of 17 (permalink) Old 10-06-2012, 07:08 PM Thread Starter
Earl's Avatar
Oh jeez, car did this again today
Earl is offline
post #15 of 17 (permalink) Old 11-21-2012, 05:14 PM
My tbird does a really weird upshift/downshift thing real fast, but only if I'm holding the shifter.
If I leave it alone, it never does it.
And, I've swapped the tranny since I noticed it.
I'm thinking that the MLPS on the side of the tranny is going bad. (I reused it)
Lonnie's tunes seem to hold gear until you let off wot.
If you cross the lines on the upshift/downshift settings in the tune, it will totally freak when you hit that point. You'd know if that were it.
I also have a weird shift that can happen at very high speeds; I've heard there's a "127mph bug", but I dunno. It seems to flip in and out of 4th.
Grog6 is online now
post #16 of 17 (permalink) Old 11-23-2012, 05:36 PM
decipha's Avatar
thats a failure to calibrate it correctly, but its not lonnies fault
SCT lacks the essential variables to tune the transmission correctly
decipha is offline
post #17 of 17 (permalink) Old 11-25-2012, 07:29 PM
I'm not using Lonnie's tunes, I'm using my own. That was a separate paragraph.
I seem to be able to control most of what I need; I seem to have my issues fixed, except for the mis-calibrated MLPS.
Grog6 is online now
