4R70W randomly stays in 2nd - TCCoA Forums
post #1 of 6 (permalink) Old 05-16-2012, 07:48 AM Thread Starter
The transmission is a 1998 4R70W transmission which has been recently been up graded with extra clutches. The valvebody is Jmoded with upgrade valves by Dirtydog. The sensors are all the proper sensors for a 1998 4R70W. Usually during normal street driving the transmission shifts with no issues. The transmission has randomly stayed in 2nd gear 3 times during normal driving and has happened 5 times on the 1/8 mile dragstrip. There are NO transmission codes and the OD light does not flash. I have a fully set of spare external/internal 1998 4R70W transmission sensors. My plan is to start by swapping out the; OSS, VSS and the MLPS. Any other insight would be helpful.
The Transmission is also in a 1998 Mustang.......
Roadhawg is offline
post #2 of 6 (permalink) Old 05-16-2012, 08:00 AM
Could be a sticking shift solenoid. May want to consider buying a shift solenoid pack.
2nd is the 'limp mode' of the tranny if the EEC senses something wrong, but you said you never get a light and there is no codes which suggests that isn't the case here.
~Rick
TCCoA Sig
post #3 of 6 (permalink) Old 05-16-2012, 09:09 AM
First thought is drawn to the MLPS. Easy way to tell would be to have a look at COMMANDED_GEAR in your datalogs.
post #4 of 6 (permalink) Old 05-16-2012, 10:47 AM
My thoughts exactly.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #5 of 6 (permalink) Old 05-16-2012, 11:23 AM Thread Starter
I was leaning towards the MLPS myself, I guess I need to add COMMANDED_GEAR to my datalogs.
Roadhawg is offline
post #6 of 6 (permalink) Old 05-19-2012, 07:30 AM Thread Starter
I swapped out the OSS, VSS and the MLPS on Thursday night. We went to the Dragstrip last night and the car had no issues with shifting when making runs down the dragstrip. I'm pretty sure it was a MLPS issue.
Roadhawg is offline
