nasty transmission leak. - TCCoA Forums
post #1 of 7 (permalink) Old 05-27-2012, 11:28 PM Thread Starter
thunderc23's Avatar
Well, I've read through the section here on the common transmission leaks for this transmission. Judging by the info presented I assume mines either TC seal or front pump seal. I understand how i'll have to drop my transmission and go from there to fix it, and I notice some talk about just upgrading the transmission. The 02 crown vic transmission from what I understand is the last year compatible transmission, but what if I want a better build transmission? what are some other great options for transmissions for these cars, auto or manual.
Also, if anyone has done the front pump seal or TC seal, are there any complications ill have to tackle along the way? and is there anything else I should look at taking care of while its down, aside of a j-mod?
thunderc23 is offline
post #2 of 7 (permalink) Old 05-28-2012, 12:20 AM
Any non police or town car 98+ 4R70w is a good trans with good hardpoints. In the event of a build a 98+ is still best to start out with (94/5s are junk). You'll want to upgrade the converter while you're here.
There's a few manual transmissions that can work, T45s, TR3650s, T56, TR6060s ect. But they'll all require some degree of fabrication to work.
post #3 of 7 (permalink) Old 05-28-2012, 02:24 PM
95_SilverBird's Avatar
drop the tranny, the front seal pops out and the new one pops in, just make sure the convertor is fully seated.. you'll know when it is. The seal is like a ~$10 part. Do do a jmod while your in there though
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
post #4 of 7 (permalink) Old 05-28-2012, 02:27 PM
I always put a little RTV Black around the edge when I press a seal in - I have seen them leak around the outside where they are pressed into the pump casing (and the rear seal around the tail shaft extension).
~Rick
TCCoA Sig
post #5 of 7 (permalink) Old 05-29-2012, 03:02 PM Thread Starter
thunderc23's Avatar
i see alot about doing a jmod, how complicated is that to do while its all dropped?
95 Thunder Chicken LX 4.6 2v
post #6 of 7 (permalink) Old 05-29-2012, 03:30 PM
It primarily involves pulling the valve body and enlarging a few holes in the separator plate to enhance clutch pack engagement/disengagement. This reduces wear and heat and increases the lifespan of both the fluid and transmission. It also firms up the shifts. The first time I did it, it took me about 3 hours - with the trans in the car.
post #7 of 7 (permalink) Old 06-07-2012, 08:35 PM
sousa632's Avatar
First time it took me about 4 hours, I just removed the Jmod and put it back to stock(mother is buying the car from me and did not want the shift kit in it) and it took me about 1.5 hours to return it to stock. All in all it's simple with a kit from RobertP or DirtyDog. Takes the guess work out of the job.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
