Uh-oh doing JMod, may have lost filter/screen... - TCCoA Forums
post #1 of 11 (permalink) Old 06-12-2012, 11:25 AM Thread Starter
96PRLBRD's Avatar
Do all 4R70W's have this little screen? I'm in the middle of doing the JMod, and I haven't found this little screen as shown in dirtydog's video. I may have to go through the fluid because maybe it dropped down somewhere...
Mine's a 96.
--> My most recent pics <--
96PRLBRD is offline
post #2 of 11 (permalink) Old 06-12-2012, 02:05 PM Thread Starter
96PRLBRD's Avatar
Anyone....? I'm heading back to the garage now to change the accumulators and springs...
96PRLBRD is offline
post #3 of 11 (permalink) Old 06-12-2012, 02:09 PM Thread Starter
96PRLBRD's Avatar
Well I found this thread, a guy with a 98 didn't have the screen either: http://forums.tccoa.com/showthread.php?t=137594
Unless someone says otherwise I'll assume it's no big deal and continue on without the screen/filter.
96PRLBRD is offline
post #4 of 11 (permalink) Old 06-12-2012, 02:12 PM
skinnytick's Avatar
I didn't have the screen.
Found the little white bobble/plug thing in the pan so I was the 1st to open it up.
skinnytick is offline
post #5 of 11 (permalink) Old 06-12-2012, 02:13 PM Thread Starter
96PRLBRD's Avatar
Thanks. There are a few sources that talk about the screen so I was wondering. But if a few others' trannies didn't have the screen then I won't get too worried that I somehow lost mine
96PRLBRD is offline
post #6 of 11 (permalink) Old 06-12-2012, 02:30 PM
Mine did not have the screen either.
DARKPHREAK is offline
post #7 of 11 (permalink) Old 06-12-2012, 03:05 PM
cobra R Thunderbird's Avatar
I also didnt have the screen..
2001 GT BULLITT #00762 stock
post #8 of 11 (permalink) Old 06-12-2012, 03:15 PM Thread Starter
96PRLBRD's Avatar
OK, great, thanks.
96PRLBRD is offline
post #9 of 11 (permalink) Old 06-13-2012, 04:17 AM
Traveler's Avatar
Its been a while since I did the J-mod, but I don't think I remember anything looking like that.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 11 (permalink) Old 06-29-2012, 11:49 AM
BUCK's Avatar
Exclamation
Mine's a 96.
96 has smaller Cone Shaped Screen that is probably still in Tranny Case.
BUCK is offline
post #11 of 11 (permalink) Old 06-29-2012, 08:26 PM Thread Starter
96PRLBRD's Avatar
I found the tiny cone filter and put it back. It was in the drain pan, luckily I read on another non-TCCoA site that mentioned that tiny thing or I for sure would have missed it. It's not actually in the valve body, it's in the transmission case but falls out when you drop the VB. I took a few pics in case anyone needs them...
96PRLBRD is offline
