Mercon V fluid change, still not shifting normally - TCCoA Forums
post #1 of 3 (permalink) Old 11-11-2012, 03:50 PM Thread Starter
WildBill4point6's Avatar
Send a message via Yahoo to WildBill4point6
Finally got to changing the tranny fluid to mercon v. Dropped pan and drianed to tc. Does shift smoother now but still acts wired dropping out of overdrive didn't do the mlps. Wondering if it wild be it. Anddddd go
-Harrison
1996 Blue 4.6 ThunderBird
WildBill4point6 is offline
post #2 of 3 (permalink) Old 11-11-2012, 05:14 PM
Originally Posted by WildBill4point6 View Post
Finally got to changing the tranny fluid to Mercon V. Dropped the pan and drained to tc. Does shift smoother now but still acts weird, dropping out of overdrive. I didn't do the mlps. Wondering if that would be it.
Sounds like it to me.
post #3 of 3 (permalink) Old 12-19-2012, 03:36 AM
TBird94's Avatar
How did you make out with the MLPS?
Just a thought: Have you ever dropped the pan, pulled the valve body, and checked the O/D servo for wear?
If you've never done this before, get good instructions. When you re-install the O/D servo, the servo pin has to be engaged with the O/D band.
My first time, I didn't know this, and the trans would shift into "neutral" instead of O/D. So, I had to pull the pan/valve body and O/D servo again, and install correctly.
TBird94 is offline
