overdrive slippage - TCCoA Forums
post #1 of 5 (permalink) Old 11-13-2012, 03:06 PM Thread Starter
overdrive slippage
Okay okay. So i dont know if my issue has been discussed and yes i did do a search but didnt find a definitive answer. I have a 97 tbird with the 3.8, well i have noticed that when im driving the car with the overdrive on the car will rev in an almost a neutral state to 3-4k rpms if i give the car more than 1/3rd throttle before it catches and goes. However, if i turn overdrive off then the trans suffers no type of slippage any any gear. Yes i have checked fluid. I am pretty mechanically inclined , however i have by no means ever been very trans or rear end savvy even though i do understand their basic design and function.
My question is what should i suspect to b the culprit. Overdrive bands, etc.
Oh and i havent had the car very long so im not sure how bad it would have been beat on lol. Any and all help is greatly appreciated.
97GreenGoblin is offline
post #2 of 5 (permalink) Old 11-13-2012, 04:15 PM
If it slips only in overdrive, then it's possible it's the band. One way to check would be to put it into manual 2 and see if it slips.
If it slips before you take off in 1st, then that's a different story. Having O/D lockout on or off has absolutely no effect on the lockup schedule or 1st, 2nd or 3rd gear's behavior. If it revs up and takes off with a bang in 1st, then your forward clutch is toast.
post #3 of 5 (permalink) Old 11-13-2012, 04:36 PM Thread Starter
In manual 1 and 2 and drive with OD off there is no slippage. In fact if im on interstate and need to pass someone i usually let of the gas and hit OD off wait for it to downshift (if i dont it revs (forgot that info lol)) then pass the car and then turn OD back on.
Oh if it matters car shows 162k
post #4 of 5 (permalink) Old 01-01-2013, 12:55 AM
I just recently developed that same problem and use the same workaround lol
I come from a dusty place.
4point6r0x0rz is offline
post #5 of 5 (permalink) Old 01-01-2013, 01:23 AM
Maybe there is scuffing/galling in the 3-4 shift actuator bore from the rod? Hard to know for sure. I'm no trans expert.
