76948-29K - OD Servo Regulator in a 97? - TCCoA Forums
post #1 of 2 (permalink) Old 01-13-2013, 02:05 PM Thread Starter
Since I will have the pan down and the VB out to put in a JModded plate, steel/bonded accumulators, and temp sensor (throwing a code), I am also putting in Sonnax 76948-02K - Pressure Regulator Boost Valve & Sleeve Kit and 76948-09 - Main Pressure Regulator Valve.
76948-29K - OD Servo Regulator is listed as 01-up, but it seems to be what I need to solve one of the things going on with my 97 Mark VIII. Can it be used in a 97?
Bangster is offline
post #2 of 2 (permalink) Old 01-19-2013, 06:33 PM Thread Starter
And the answer is...no, it will not. The VB got an overhaul in 2001 and it was the OD circuit that was the big change.
Bangster is offline
