How much fluid? 4R70W - TCCoA Forums
post #1 of 4 (permalink) Old 02-14-2013, 08:56 PM Thread Starter
bagged95's Avatar
Question How much fluid? 4R70W
Im wanting to change the fluid and filter in my 95 and it's got the 4r70W transmission. I plan on draining the TC through the bell housing, dropping the pan and putting on a new WIX filter and gasket but I dont know exactly how many quarts and what type of fluid that I will need to refill the transmission. It was rebuilt about 5-6 years ago and only has roughly 15K miles on it but is otherwise stock.
bagged95 is offline
post #2 of 4 (permalink) Old 02-14-2013, 09:35 PM
Rayo's Avatar
Thunderbird Transmission Refill Instructions
Fill the transmission through the dip stick tube.
Add 6 qts. of MERCON-V at first.
Hold the brake firmly and start the engine.
Move the shifter level through the gears, stopping at each indent or position.
Stop the engine and add 6 more quarts of MERCON-V to the dip stick tube.
Stop again at 10 qts. and repeat the process listed above.
The 4R70W holds 12-13 quarts of ATF fluid, do not over-fill the transmission.
*NOTE: If you have an auxiliary transmission cooler, you will require 13-14 quarts of ATF.
For More Information Look Here
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 4 (permalink) Old 02-14-2013, 10:17 PM
96PRLBRD's Avatar
p.s. Keep in mind you don't add like 12 all at once. There is a procedure, you'll have to look around for it. Basically you add about 6 quarts, start the engine, go through all gear positions holding your foot on the brake, add 2 more quarts, repeat, when you get to 10 quarts, only add 1/4 quart at a time, etc. Search around you'll find the specifics (it's in the factory service manual).
--> My most recent pics <--
96PRLBRD is offline
post #4 of 4 (permalink) Old 02-18-2013, 12:53 PM
BUCK's Avatar
Lightbulb
Originally Posted by Swanny View Post
p.s. Keep in mind you don't add like 12 all at once. ).
ABSOLUTELY~! - Unless you like mopping up the expensive ME$$ after it overflows & pours out of your Yoke Seal ~!
BUCK is offline
