HELP! Trans issue! Where does this piece go? - TCCoA Forums
post #1 of 7 (permalink) Old 03-31-2013, 06:01 PM Thread Starter
ThunderKev's Avatar
I am posting in here for hopes to get more views... Dropped my trans pan to change my filter and fluid, and this came with!
This must go somewhere, right? I'll check back periodically. But if someone can tell me where that should go, I'd really appreciate it... Thanks
1995 Ford Thunderbird LX in Midnight Blue - 4.6L V8 Currently at 78k miles. Assembled 3/22/95 - Reborn October 22, 2013 with tons less rust
1989 Ford Thunderbird S/C in White - 3.8L SC at 121k Miles.
Other ride:
1995 Ford Taurus LX Station Wagon, Old Man Tan, with the ever so powerful 3.8L V6 Essex!
2002 Mercury Sable LS Premium - Wife's car - Old man tan as well with a Duratec! Leaky Fun with oil everywhere 89k miles
ThunderKev is offline
post #2 of 7 (permalink) Old 03-31-2013, 06:06 PM
Trash can or your souvenir drawer. It's a factory shipping plug with no other purpose. You don't need to replace it anywhere.
I forget what it's called but this comes up once or twice a year....
BTW that pan is really clean.
post #3 of 7 (permalink) Old 03-31-2013, 06:14 PM Thread Starter
ThunderKev's Avatar
Oh really? Ahhh, that's the biggest sigh of relief. I did do a trans flush by pulling the return line, added a few qts of Mercon V, then repeated a few times. It was a bit worse. In that case, I can start reassembly. Thank you very much! I probably would have found it if I didn't panic and did a search
So that thing was just riding around my trans pan... Lol, how about that.
Other ride:
post #4 of 7 (permalink) Old 03-31-2013, 06:30 PM
bowez's Avatar
I knew I was going to see that.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #5 of 7 (permalink) Old 03-31-2013, 06:31 PM
rmfk13's Avatar
Keep it incase you ever have to pull the tranny, it makes a good plug for the dipstick hole so you don't spill fluid everywhere
Rob
rmfk13 is offline
post #6 of 7 (permalink) Old 03-31-2013, 08:23 PM
nall_one's Avatar
+1 it is indeed rather nice as a plug. suppose that could have something to do with that being its original purpose.
yeah, they ship the trans with that installed in the dipstick hole, then during assembly they just pop the stick in and push that plug down into the pan.
all it really says is that your trans pan has never been off. looks like it was running really good and healthy too.
just make sure you use the reusable gasket, their much much MUCH better then any of those rubber pieces of [email protected] that come in the parts store kits. filters are fine, just toss that rubber thing in the trash.
look it over for damage, if none is found reuse it, otherwise head to the local dealership and buy a new one.
also, now would be a great time to get yourself a 96+ pan and filter. they arnt susceptible to dry sump under hard cornering. 95 and down were know for slipping out of gear under hard turns when the fluid sloshed to one side and the sump sucked air into the valve body.
nall_one is offline
post #7 of 7 (permalink) Old 03-31-2013, 10:11 PM Thread Starter
ThunderKev's Avatar
Ah, that would have been good to know about a few hours ago. I already reinstalled it with the factory 95 pan/gasket.
Seems I added a bit too much fluid, so I'll have to siphon that out. Next time I play around inside my transmission I'll do that. Which may be in the near future. I've heard a lot of good things about J-Modding it. I kind of do want my trans to last, but right now I just want it to be healthy, and hopefully take care of the vibrating on accelerating for now.
Other ride:
