Q about gearsets - TCCoA Forums
post #1 of 7 (permalink) Old 04-30-2013, 08:41 PM Thread Starter
germz1986's Avatar
Q about gearsets
Hey all, I'm in the (very) slow process of saving money and modding my 96 bird.
So far I have a tweecer on the way here as I type, and putting on a tranny cooler this weekend.
I drive this car daily, and do a fair bit of hwy driving, not overy worried about going fast, but I am worried about fuel milage.
I will be changing gear sets soon, more than likely going to either 3.27 or even 3.08s.
I also see that the aode trans has a (very) smaller OD 4th, .67 vs the 4r70w .7.
I play on having the tranny built for my (eventual) turbo stroker build, Is it possible to swap the od gear from the aode into my 4r70w?
1997 Royal Blue Metallic 4.6l
Pioneer P8400H
Diamond Audio D6 5x7's Driven by Hiffonics 4ch
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
germz1986 is offline
post #2 of 7 (permalink) Old 05-01-2013, 05:06 AM
The AOD gearset is notoriously weaker than the 4R70W's. Your car also has a 3.27 stock from the factory. If you're concerned with fuel mileage, you can go to a 3.08 (or if you're absolutely sure you don't care about the loss of torque multiplication) even a 2.73 to keep the highway RPM down.
However a better way to get more fuel economy is to get the car tuned by someone who knows what they're doing and to ensure that all the regular maintenance items are taken care of. When stock it wasn't uncommon for my car to get averages of 30 MPG on the highway.
post #3 of 7 (permalink) Old 05-01-2013, 08:53 AM Thread Starter
germz1986's Avatar
I see, well ty for that, I wasnt aware the gearset was weaker, that is good to know.
I have done all regular maint, car has fresh set of wire, plugs, and coils. I change the oil every 3k and run full synthetic. Tranny gets a fluid change every 10k.
Last long road trip I went on (600+ miles) I averaged about 24 mpg.... I had the cruise set @ 75 most of the way (speed limit is 70 most of that trip), also had a fair bit of luggage.
I have a 97 lincoln conti, that with the same load of ppl and luggage gets about 27 @ the same speeds.
And I think your right, i'll likely go with the 3.08's
Pioneer P8400H
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
post #4 of 7 (permalink) Old 08-23-2013, 03:53 PM Thread Starter
germz1986's Avatar
Resurrecting an old thread of mine here. Since posting this, i have learned that you never make top gear pulls with this trans.
Something about the OD band not being all that strong.
Knowing this. Would it still be ill advised to say swap just 4th from the aode trans when i build/rebuild this trans?
Pioneer P8400H
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
post #5 of 7 (permalink) Old 08-23-2013, 04:56 PM
bowez's Avatar
If memory serves you already have the 2" OD band (the best available to my knowledge). Mechanically a AODE is a 4R70W if you are to swap any it would need to be 03+.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #6 of 7 (permalink) Old 08-23-2013, 07:30 PM
You have to swap all the gears this transmission only has one planetary set and the aode overdrive is very close to 4r70w anyway, the 1st gear of 4r70w makes the car launch better, but aod(E) gearset is more evenly spaced. All 4r70w's have a 2 inch band it's the late mechanical diode that is so much better.
post #7 of 7 (permalink) Old 08-23-2013, 07:39 PM Thread Starter
germz1986's Avatar
tyvm gents
Pioneer P8400H
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
