Orange 20 tooth? - TCCoA Forums
post #1 of 11 (permalink) Old 05-13-2013, 04:31 PM Thread Starter
Buckcreekbilly's Avatar
Orange 20 tooth?
I finally have time to work on my Bird. I swapped over to 3:55 with trac lok. I want to correct my speedo and from what i'm reading here, i need the orange 20 tooth, is this correct? I have 255/60-15 tires on rear and they were very close to correct with stock rearend gears. TIA
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #2 of 11 (permalink) Old 05-13-2013, 06:13 PM
You need a 19 tooth, not a 20.
post #3 of 11 (permalink) Old 05-13-2013, 10:19 PM Thread Starter
Not doubting you, you know more than me. I got the 20 tooth idea from here http://forums.tccoa.com/showthread.php?t=132130
Are you suggesting 19 tooth due to my tire size? Thanks again
post #4 of 11 (permalink) Old 05-14-2013, 06:34 AM
The method to calculate needed speedo gear is to multiply the number of output shaft teeth (7) by the rear gear ratio (3.55) and the number of tire revs per mile (745), then divide by 1000. Your result is 18.51 because your tire is so large. As the tire wears down and decreases in diameter your speedo will get more accurate.
post #5 of 11 (permalink) Old 05-14-2013, 09:11 AM Thread Starter
Is there a 19 tooth available for my transmission? Only see a 19 for 8 tooth output shaft. Mine is a 7 tooth shaft.
post #6 of 11 (permalink) Old 05-14-2013, 09:49 AM
http://www.americanmuscle.com/speedo...ooth-auto.html
post #7 of 11 (permalink) Old 05-14-2013, 09:49 AM
Same gears, but the number of teeth you need for a certain rear ratio changes (by 8:7 or 7:8, depending on which way you're talking about).
PATC shows a 19 tooth gear at http://www.transmissioncenter.org/Fo...eter_Gears.htm .
They're local to me, but I can't say past that. That, and they've been there 90 forevers, it seems *grins*
Before you order, what was your old rear ratio, what gear did you have, and what's the new ratio?
Ideally, you compute the number of teeth you need from the same ratio as the one between the two rear ratios, and order that.
That is, if you went from 3.08 to 3.31, and your old one was an 18 tooth, then you'd want ( 3.31/3.08 ) * 18 teeth on it ... or in your case, 19 teeth (nearest match).
RalphP is offline
post #8 of 11 (permalink) Old 05-14-2013, 12:21 PM Thread Starter
Thanks guys
post #9 of 11 (permalink) Old 05-14-2013, 05:12 PM Thread Starter
Ordered one today from local Ford dealer, be in tomorrow $7.95 plus tax.
post #10 of 11 (permalink) Old 05-14-2013, 06:12 PM
I missed this, but this is the calculator I use.
From our friends at SCCOA:
http://www.sccoa.com/faq/speedgr.html
I thought 19 was stock?
Grog6 is online now
post #11 of 11 (permalink) Old 05-14-2013, 06:59 PM
18 is stock. I use my own calculator.
http://alhscds.dyndns.org/TireCalc.html
