Trans shop for JMOD in Dallas area - TCCoA Forums
post #1 of 6 (permalink) Old 05-22-2013, 01:27 PM Thread Starter
97Lincat's Avatar
Send a message via Yahoo to 97Lincat
Can anyone make any recommendations in the Dallas area for trans work?
I pulled the tranny from my cougar and swapped in one from my old Mark VIII (TC and flexplate as well), but would like to have the one I removed get the JMOD and accumulator updates, so it will be a waiting/ready replacement when the Mark VIII one goes out on me. Also will be looking for a new F63 TC to go on it, depending on budget.
Most tranny shops in the area I've talked to want to sell an additional shift kit, like Transgo or B&M, but don't seem to know about the JMOD procedure for some reason, or at least they play dumb about it.
I know, I could probably do it myself and come out just fine, but I'd rather someone who has all the needed tools available, and some prior experience do it.
Thanks in Advance!
Mikey
97lincat
97 Cougar w/Mark VIII donor for all but engine.
97Lincat is offline
post #2 of 6 (permalink) Old 05-22-2013, 01:42 PM
Buy an already drilled plate from Rob (look in the parts for sale section, or look for his posts). Even if you do the drilling yourself, all that is needed is a drill, specific bits (which can be tough to find, but not impossible), and pretty hefty internal snap ring pliers.
I drilled out my own plate for my 97 Cougar, and was happy with the results, but decided to buy the kit from Rob for my 97 Mark VIII, and am happy with the results as well.
Stay away from those shift kits, just do the specified separator plate drilling, check an see if you have already have the new 1-2 and 2-3 style pistons (and also if new bonded steel/rubber one, that it isn't worn, torn, cracking, etc). I also replaced the pressure regulator and boost valve with Sonnax upgraded/not worn out parts.
Bangster is offline
post #3 of 6 (permalink) Old 05-22-2013, 02:04 PM
Get in touch with RobertP he sells pre made kits
http://robstireandauto.com/
post #4 of 6 (permalink) Old 05-22-2013, 02:52 PM Thread Starter
97Lincat's Avatar
PM to Robert sent. Thanks!!!!
97Lincat
97 Cougar, 4.6L2v, w/Mark VIII TC/flexplate/Trans/Fan/LCA's/Brakes/wheels F250HD trans cooler.
97Lincat is offline
post #5 of 6 (permalink) Old 05-22-2013, 03:03 PM
sik97bird's Avatar
Well if you get the parts I have no problem helping or showing you how to put it in. I have all the tools needed.
I'M BACK
97 Supercharged Ford Thunderbird with warpdrive
Check out my Gallery
vist the Man RobertP at www.robstireandauto.com
sik97bird is offline
post #6 of 6 (permalink) Old 05-22-2013, 06:36 PM
Pm replied
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
