Transmission Slipping on Steep Hill - TCCoA Forums
post #1 of 4 (permalink) Old 05-24-2013, 02:14 PM Thread Starter
1995 Thunderbird - 280K Miles - Original Transmission - Serviced within the last 20000 miles/18 Months - Fluid flush
Transmission slips (Like Neutral) when leaving grage on very steep hill - Generally will re-enage if you let off the gas and try again. Does not heppen any other time. Transmission works well in all other conditions. Checked Fluid and it's full.
Any thoughts on cause of problem
Geoffrey Moss is offline
post #2 of 4 (permalink) Old 05-24-2013, 02:22 PM
The early trans has a flat pan, which on steep angles can allow it to suck air. The fix is to replace the pan and filter with one for a 96+ 4R70, which has a sump in the center that the filter picks up fluid from.
post #3 of 4 (permalink) Old 05-25-2013, 05:27 AM Thread Starter
Thanks - That sounds like that's very likely it - As you might suspect the transmission shop was ready to sell me a rebuilt transmission!
post #4 of 4 (permalink) Old 05-26-2013, 08:25 AM
FWIW, I've bought those 96+ pans for about $24 at the Ford stealership.
I happened to try and grab one from Pick-N-Pull while I was there and they wanted $30 for it!
I told them I can get one for a little more than $20 brand new, but they don't care (bunch of ripoffs).
~Rick
TCCoA Sig
