Forward Clutch - TCCoA Forums
post #1 of 17 (permalink) Old 06-22-2013, 11:15 PM Thread Starter
Forward Clutch
What would cause the forward clutch to burn up?.. All the steels have hot spots on them and the frictions are worn smooth.
The 1/2 accumulator lower spring was broken.
What I do know is:
There where no codes
I have the correct fluid level.
Reverse works fine
Trans will not shift into 1 or 2 when either in O/D or manual 1 or 2.
All other clutch packs look good.
I would need to rev the engine up to about 4500 rpms to get moving.. slowly but once I get up to about 35 40 mph it seems like 3rd gear is engaged and will shift into 4th.
Trans is out of 99 Mustang.
Planning on doing a couple of pressure tests at the ports over the weekend.
Thanks for any help or direction
IATCUYB is offline
post #2 of 17 (permalink) Old 06-23-2013, 12:29 PM Thread Starter
Just a follow up.. connected two gauges to the trans.. one to the line port and the other to the forward port. What I got was 53 psi on the line side and then when shifting into O/D the forward side only climbed to 30 psi. This is should indicate a bad 1/2 solenoid correct?
IATCUYB is offline
post #3 of 17 (permalink) Old 06-24-2013, 10:18 AM
got a leak somewhere i would say pissing pressure out somewhere
dabeetereater is offline
post #4 of 17 (permalink) Old 06-25-2013, 12:04 PM
BUCK's Avatar
Lightbulb
Originally Posted by IATCUYB View Post
What would cause the forward clutch to burn up?.. All the steels have hot spots on them and the frictions are worn smooth.The 1/2 accumulator lower spring was broken.
My guess is poor 2-3 Accumulator setup.
BUCK is offline
post #5 of 17 (permalink) Old 07-04-2013, 11:41 AM Thread Starter
With a possible leak being somewhere would it more than likely be in the valve body?
I thought the 1/2 accumulator was only for softening the shift from 1 to 2?
IATCUYB is offline
post #6 of 17 (permalink) Old 07-04-2013, 01:03 PM
BUCK's Avatar
Lightbulb
You'll want to "absorb" the greatest 4r70w Article of all time:
http://forums.tccoa.com/showthread.php?t=106348
BUCK is offline
post #7 of 17 (permalink) Old 07-05-2013, 10:41 AM Thread Starter
Buck,
Thanks for the info.
I do have a few questions though.
So the 2/3 accumulator is applying pressure to the forward clutch when the gear select is in either manual first or O/D when starting in first?
Is there a way to test or check the 2/3 accumulator and the 1/2 accumulator?
Then the valve body.. I can always take it apart, clean it up and put it back to together but again is there a way to check the various valves?
Again, thanks for the help.
IATCUYB is offline
post #8 of 17 (permalink) Old 07-07-2013, 10:38 AM
BUCK's Avatar
Lightbulb
I'm NO Guru but here's what I've absorbed fm Guru's:
Go to www.sonnax.com for Main VB Parts / fixes via our Vendors.
DD always said to leave a 1-2 Accumuator Spring IN the V6's as he actually WANTED some flare to help the V6 "cope" w/ 1-2 Shift.
You'll be deleting any 2-3 Accumualator Spring & any "delay" in that Shift is hard / eventually fatal on Forward Clutches.
I'm kinda worried about your Pump at this point but you'll be inspecting that of course.
Best to go to inexpensive Air to Fluid Cooler & delete Rad Tranny Fluid Cooler for your new / rebuilt Tranny.
BUCK is offline
post #9 of 17 (permalink) Old 07-07-2013, 11:54 AM Thread Starter
Thanks for the info..
If I have line pressure though at idle that is within the spec range and that pressure increases as it should with engine rpms that should indicate the pump is working correctly?
IATCUYB is offline
post #10 of 17 (permalink) Old 07-07-2013, 01:31 PM
BUCK's Avatar
Thumbs up
I would certainly think so.
BUCK is offline
post #11 of 17 (permalink) Old 07-08-2013, 05:05 PM Thread Starter
I think I am pretty sure I found the problem.. the lip seal under the spring in the forward clutch drum. Would post a pic but not able to since I new.
Thanks for the help guys
IATCUYB is offline
post #12 of 17 (permalink) Old 07-09-2013, 03:40 AM
BUCK's Avatar
Question
I think I am pretty sure I found the problem.. the lip seal under the spring in the forward clutch drum. Would post a pic but not able to since I new. Thanks for the help guys
Seems like I tested those Seals with Air to Apply Piston after assembling Pack (I used Plastic Shim Stock as Lip Seal protector)- I'd think the heat from slipping could damage them too (41/42 on Exploded view) - So unless Seals were recently installed incorrectly & not tested & that caused "Failure to fully Apply " then question could still be why it failed to FULLY Apply when Seals were good & heat from slipping Clutches killed Seals... Right___?
BUCK is offline
post #13 of 17 (permalink) Old 07-09-2013, 01:53 PM Thread Starter
Eh.. I went at this so half a**ed I am ashamed of myself.
The car sat for over a year. My guess between that and a teenager having the car before I did is the combination for the seals and forward clutch to go bad.. more so for it sitting such a long time..
IATCUYB is offline
post #14 of 17 (permalink) Old 07-09-2013, 06:58 PM
Forward clutch seal is blown
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #15 of 17 (permalink) Old 07-23-2013, 08:34 PM Thread Starter
Any tips or tools for installing the seals (sliding the pistons into drums with new seals)?
IATCUYB is offline
post #16 of 17 (permalink) Old 07-24-2013, 07:06 AM
88grandmarq's Avatar
Send a message via AIM to 88grandmarq Send a message via Yahoo to 88grandmarq
yeah, you need the lip seal protector tools.
http://www.ctpowertrain.com/servlet/...OD-AODE/Detail
I rebuild AOD/AODE/4R70W/4R75E transmissions....Check out my Facebook page: https://www.facebook.com/pages/North...48414635312478
88grandmarq is offline
post #17 of 17 (permalink) Old 07-24-2013, 07:35 AM
BUCK's Avatar
Lightbulb
Plastic Shim Stock worked for me - I just cut it w/Scissors to suit.
BUCK is offline
