Yeah, I work on vans too.... - TCCoA Forums
post #1 of 3 (permalink) Old 07-24-2013, 07:09 AM Thread Starter
88grandmarq's Avatar
Send a message via AIM to 88grandmarq Send a message via Yahoo to 88grandmarq
Arrow Yeah, I work on vans too....
Had a 2004 E-250 (5.4L/4R70W) towed to me over the weekend. Owner of the Van runs a local painting/remodeling business, says his crew "drove it until it stopped pulling".
The transmission had no engagement in ANY Forward gears, not even low 1, however reverse worked perfectly. The owner dropped the pan and replaced the filter/fluid, before he towed to me, he claims there was little to no debris in the pan.
Knowing vans in general are a pain to work on, I feared the worst. I was pleasantly surprised to find most of the transmission bolts and the wire connectors were easily accessible from the top, once the engine cover was removed;
Once the transmission was out, I found the OD band was burned and almost worn to the rivets. The forward clutch pack was burned because the outer piston seal was ripped in multiple places. No forward clutch engagement = No go forward!
I found NO other problems with this transmission. The direct, reverse and intermediate clutches had minimal wear, even with 100K on the odometer.
Going back together I discarded the wave plate in the forward clutch pack and increased it to 6 clutches. All the clutch pistons got new seals installed and I upgraded to OD band to the latest Ford unit, which uses a Hi-Energy carbon material that resists burning. Ford part # 7L3Z-7F196-A.
The OD servo return spring was updated to a softer spring, this allows the OD band to apply faster and hold more firmly. Ford part # F2VY-7F201-A.
To aid in better shifting I enlarged several holes in the valve body separator plate and installed updated shift valves from Sonnax.
I rebuild AOD/AODE/4R70W/4R75E transmissions....Check out my Facebook page: https://www.facebook.com/pages/North...48414635312478
88grandmarq is offline
post #2 of 3 (permalink) Old 07-27-2013, 09:59 AM
BUCK's Avatar
Question
Nice PIX & yeah that access sure beats a 30 Inch Extension ~! - So you are favoring that updated Ford OD Servo Pin Soft Spring setup now over the previous reccommended Sonnax O Ringed Servo Pin with Preloaded Spring Option ?
Other cool thing here is we have Pic of Truck VB Sep Plate w/"JMOD" holes on TCCOA.
BUCK is offline
post #3 of 3 (permalink) Old 07-28-2013, 04:46 PM Thread Starter
there was no evidence of wear in the case or on the OD servo pin, so reused the old servo. I only used the updated Sonnax shift valves, not the OD pin.
The softer spring just helps the band engage faster and hold better.
