High stall or slipping? - TCCoA Forums
post #1 of 4 (permalink) Old 08-07-2013, 03:22 PM Thread Starter
95_SilverBird's Avatar
Ok, I have a 4k stall that I bought used. I put it into my tranny and did a jmod. The car was amazing. Now about 6 months later it seems to be slipping. I cant tell if its the tranny or the converter. How do I tell? This also runs extremely hot. Even with a 46k btu cooler I've measured a hot of 260 deg before my sensor failed. You can feel the heat putting your hand between the tunnel and the seat. Funny thing is the fluid looks ok and doesn't smell burnt?? I'm planning on a new tranny and it'll maybe depend on whats wrong with this one. If the tc is shot I'll put a stick in the car, while if its ok I'll replace the auto
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
post #2 of 4 (permalink) Old 08-07-2013, 03:47 PM
A video of driving the car under different acceleration rates would help to diagnose it. Also, if the car was fine for a few months after installing the converter, then it sounds more like a problem in the trans, not the converter.
post #3 of 4 (permalink) Old 08-07-2013, 06:13 PM Thread Starter
Thats my assumption. I was just surprised the amount of heat that its running. Is a tranny capable of making that much heat? Again about 260deg with a 46k btu cooler
post #4 of 4 (permalink) Old 08-08-2013, 06:13 AM
If it's getting that hot something is wrong in the transmission and/or converter. That kind of heat will cause slippage by hardening the seals.
