trans leak while parked - TCCoA Forums
post #1 of 18 (permalink) Old 10-04-2013, 06:59 PM Thread Starter
steamer471's Avatar
Well my 96 a/c compressor went out this spring and she has not been driven much this summer. Robert P. j-modded the tranny 2 year ago and it works great. Never leaked until today, I looked under it, and there is a big spot of tranny fluid under the passenger side.
Now I have another 96 I have had for five years as a parts car that does the same thing. Does anyone know where this might be coming from? Is this from it sitting up?
1997 Mark 8 LSC
Former owner:
1996 Thunderbird lx 4.6
1994 Thunderbird lx 4.6
steamer471 is offline
post #2 of 18 (permalink) Old 10-04-2013, 07:17 PM
miller1995's Avatar
Dip stick tube o-ring.
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #3 of 18 (permalink) Old 10-04-2013, 08:54 PM
Or the manual lever shaft, the rear seal, the tailhousing gasket, the pan gasket, the cooler lines, the front pump seal, or the torque converter.
One of those, anyway.
Unless you have a porous tranny casting... That just sounds nasty.
post #4 of 18 (permalink) Old 10-04-2013, 09:07 PM Thread Starter
steamer471's Avatar
Yeah well unless i'm there to see it drip I guess i'll never know. I've looked at all these usual suspects but no obvious culprit.
1997 Mark 8 LSC
Former owner:
post #5 of 18 (permalink) Old 04-10-2014, 12:38 AM
Mgino96tbird46's Avatar
I think my dipstick tube is leaking too. My pan is wet after driving and I'm getting some trans fluid on the front of my 3rd cat. While I'm in there, should I do the pan seal too? Tail shaft looks fine, as far as I can tell. It seems to only get wet once the fluid is up to full operating temp. I can smell the fluid from outside of the car when it's hot too.
Mgino96tbird46 is offline
post #6 of 18 (permalink) Old 04-10-2014, 07:12 AM
Rayo's Avatar
Check your fluid level..Your transmission could be overfilled..
When there's too much fluid in there it starts foaming when hot, and will run out of places..Making it look like a fluid leak..
If you change the pan gasket..Use the rubber bonded piece with the metal core..That one's reusable..
1991 Ford Thunderbird Sport
Rayo is offline
post #7 of 18 (permalink) Old 04-10-2014, 08:20 AM
That's a common leak. Rob had to replace my DS tube gasket once too.
post #8 of 18 (permalink) Old 04-10-2014, 11:59 AM
I have a leak too, since I got the car a little over a year ago. I narrowed it down to what I thought would be a pan gasket seeping. Changed that and still had a good leak especially on inclines nose up. Then I seen fluid coming from the tail shaft seal, changed that ( it's rough with exhaust connected lol) still to leak. Come to find out it's leaking from the yoke. I even called Alan at dd and he said it happens and to just silicone it. A year later still haven't got yo it.
95 Silver Frost. 2.5" Straight Pipe, 16" Black XR-7 wheels, Silencer Delete, Homeade CAI (RichardM Clone), PowerStop Drilled/ Slotted Rotors, 97 Console. Awaiting Install, 96/7 Headlights and Tails.
Searching for 96/7 Hood.
96sportchicken is offline
post #9 of 18 (permalink) Old 04-10-2014, 01:43 PM
I jacked the car up and looked at it more. Looks like the dipstick tube isn't leaking, but the tail shaft housing gasket is. Tail shaft section needs to come off. The second pic is after I sprayed some brake parts cleaner. I felt all around the dipstick tube to check, it was gritty, but dry.
post #10 of 18 (permalink) Old 04-10-2014, 02:59 PM
Michael check the tightness of the extension housing bolts, I noticed the housing is missing it's vibration dampener and have seen these self loosen many times before. It's worth checking.
post #11 of 18 (permalink) Old 04-10-2014, 04:29 PM
Interesting. What is the torque spec for those bolts? 15-25 ft-lbs?
Also, when I do replace that gasket, other than taking out the vss, is there anything special I need to do or anything I need to look out for when removing and installing the tail shaft housing? Anything I need to align a certain way, etc.
I'll clean everything up and check the torque on the bolts first.
post #12 of 18 (permalink) Old 04-10-2014, 07:16 PM
My driveshaft was bad when that happened to me; if it's stock, take it alll the way out and look at it carefully.
I had a bad ujoint, and the ds was delaminated, front and back.
The one on Lazarus I replaced pro-actively had spun inside itself; I thought it was the tranny freaking out, lol.
I replaced both at the same time, not as funny.
I saw the ds later, after I was done, of course.
post #13 of 18 (permalink) Old 04-10-2014, 07:56 PM
Thankfully that's not a problem for me since I have one of the best drive shafts for these cars. lol
post #14 of 18 (permalink) Old 04-10-2014, 09:01 PM
Rayo's Avatar
When replacing the Extension Housing Gasket..Use the updated gasket that has a silicon bead impregnated into it..The Ford piece is preferred..
Here's what it looks like:
Just to reiterate what I was saying earlier about foaming..Check your breather cap to see if it's dry, or has been leaking out of there..
Rayo is offline
post #15 of 18 (permalink) Old 04-10-2014, 10:12 PM
I shouldn't need any to lay any rtv, should I?
post #16 of 18 (permalink) Old 04-11-2014, 12:22 AM
NO! RTV has no business near these transmissions. However you may choose to lock tight the fasteners to the extension housing... I'd recommend permatex/locktite blue for that.
post #17 of 18 (permalink) Old 04-11-2014, 07:44 AM
Roger that. I'll get this knocked out later today when I get out of class.
post #18 of 18 (permalink) Old 04-11-2014, 06:51 PM
Does anyone know how much fluid I'll lose when I unbolt the tail shaft housing?
The Ford gasket is just paper.
I never got around to doing it today since the auto hobby shop on base was too busy.
