j mod vs shift kit - TCCoA Forums
post #1 of 20 (permalink) Old 02-23-2014, 11:54 AM Thread Starter
j mod vs shift kit
I've been doing research and im trying to decide which is better. Should i go with the jmod or should i run to summit and get this shift kit. i replaced my rear end with a limited slip 3.73. Just wasn't some quicker firmer shifts any help would be greatly appreciated
live4rpm is offline
post #2 of 20 (permalink) Old 02-23-2014, 11:57 AM
Hands down J-Mod is your best bet. See RobertP's web add in my sig or PM him he sells pre-made kits.
post #3 of 20 (permalink) Old 02-23-2014, 12:00 PM
dDUBb's Avatar
J-mod is a shift kit - definately your best bet for shifting written by a former Ford transmission engineer. There are a few other kits available, depending on which one you are looking at from Summit .. the Transgo kit does some strange things like adding an external pressure relief valve which was not recommended by the author of the J-mod.
dDUBb is offline
post #4 of 20 (permalink) Old 02-23-2014, 12:01 PM
The J-mod is a shift kit designed by one of the Ford engineers who designed the 4R70W. Hands down your best option.
post #5 of 20 (permalink) Old 02-23-2014, 02:01 PM
96PRLBRD's Avatar
JMod x4.
--> My most recent pics <--
96PRLBRD is offline
post #6 of 20 (permalink) Old 02-23-2014, 08:07 PM
Yes jmod I've kits in stock
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
All made possible with Braincoating's ported manifolds
RobertP is offline
post #7 of 20 (permalink) Old 02-23-2014, 09:05 PM
Mgino96tbird46's Avatar
Definitely J-mod....I mean, it was designed by the transmission engineer! lol
Mgino96tbird46 is offline
post #8 of 20 (permalink) Old 02-23-2014, 10:26 PM
96dirtybird's Avatar
J-Mod, end of discussion. Close this thread.
96dirtybird is offline
post #9 of 20 (permalink) Old 02-24-2014, 12:54 AM
Paulyrats's Avatar
Robert
RobertP How much does a jmod kit cost?
-PAULYRATS-95-4.6L-THUNDERBIRD-LX
SVO SUPERCHARGER @ 9PSI
70MM TB,76MM MAF
30# INJECTORS, 255 LPH FUEL PUMP
SNOW PERFORMANCE METHANOL INJECTION
SCREAMIN DEMON COILS, LIVEWIRES PLUG WIRES
CUSTOM LONGTUBE HEADERS,2.5" DUAL EXHAUST
JMODDED 4R70W, 9.5 3200 STALL TC
93 MARK VIII DS, 3:73 REAR GEARS
TUBULAR REAR UPPER CONTROL ARMS
IRS REAR TORSIONAL LOAD BRACE
REAR STRUT TOWER BRACE, SCP PINION BRACE
HEAVY DUTY POLY REAR DIFF MOUNT
1.5 DROP EIBACH SPRINGS
18x9 SALEEN REPLICA WHEELS
COBRA R STYLE HOOD
Paulyrats is offline
post #10 of 20 (permalink) Old 02-24-2014, 08:49 AM
110 delivered
10.75 @128.38
RobertP is offline
post #11 of 20 (permalink) Old 03-20-2014, 09:11 AM
tonyblitz1's Avatar
I did some research on it and frankly I don't understand why people would trade extra trans wear and reduced power just to get "that signature slushbox feel"... can anything good be said about shift overlap?
tonyblitz1 is offline
post #12 of 20 (permalink) Old 03-20-2014, 09:42 AM
I have a feeling Ford's engineers determined the life expectancy on the unit with the amount of slip and wear experienced under normal driving conditions and found that it met or exceeded the target life expectancy of the vehicle or powertrain as a whole.
The MN12 was never marketed as a performance automobile to compete with the Mustang... It was marketed as a "Personal Luxury Coupe" - harsh shifts don't fit in with the term "Luxury" as one would see it from the factory.
post #13 of 20 (permalink) Old 03-20-2014, 02:51 PM
Lafayette's Avatar
110 delivered
Do you have one for a 1994 4R70W , and what is included , and also what else do you recommend that I replace while I'm in there ? Also I had a tune done last summer and this changed the shift points/quality , will I need a retune ?
Lafayette is offline
post #14 of 20 (permalink) Old 03-20-2014, 03:16 PM
tonyblitz1's Avatar
makes sense I guess, the T-bird is less like a big Mustang and more like a small Lincoln
post #15 of 20 (permalink) Old 03-20-2014, 06:42 PM
Yes I have the the 94 kits in stock it comes with accumulators both 1 and 2 and both valve body gaskets, the new springs for the 1-2 accumulator and a filter usually they come with the 96 and newer filter as I do recommend changing to. The newer style pan as it helps with fluid starvation and the trans should last a long time then
Robert
10.75 @128.38
RobertP is offline
post #16 of 20 (permalink) Old 03-21-2014, 04:06 AM
Lafayette's Avatar
Sorry to waste your time Robert , I already have the majority of the parts listed. I must have misunderstood your web site , I thought that there might be a modified separator plate in the kit .I'm sure we'll get another chance to do business.
post #17 of 20 (permalink) Old 03-21-2014, 07:26 AM
Yes it does come with a modified seperator plate hence why I need the old plate back, I've posted this numerous times here on the forum, the only thing the kit is missing is fluid and tools
Robert
10.75 @128.38
RobertP is offline
post #18 of 20 (permalink) Old 03-21-2014, 02:43 PM
Lafayette's Avatar
Robert
Okay , I'll take one. How do we proceed ? I assume you need some details and maybe a little cash. The car is still put up for the winter and I won't be able to get it out for at least a month , I'm in the parts gathering stage right now. I did see someone selling one of your kits and making reference to sending you the removed separator plate , but that's the only time I've ever seen it mentioned.
post #19 of 20 (permalink) Old 03-21-2014, 08:59 PM
Ill pm u, sorry it's been a rough 2 weeks and ive had late nights working
10.75 @128.38
RobertP is offline
post #20 of 20 (permalink) Old 03-23-2014, 07:09 PM
Lafayette's Avatar
Hey no problem Robert , been there. Plus my search technique's aren't that great.
