Deep Sump Pan # - TCCoA Forums
post #1 of 3 (permalink) Old 03-19-2014, 02:56 PM Thread Starter
Lafayette's Avatar
Deep Sump Pan #
So I searched for part #"F6AZ-7A194-A" Deep Transmission Pan and the following # came back as a replacement "6L3Z-7A194-A" does anyone know if this will work on my 1994 Thunderbird 4R70W , although the pan appears the same , everything leads it back to a F150 or a U Haul truck or something. Thank You in advance.
Lafayette is offline
post #2 of 3 (permalink) Old 03-19-2014, 04:54 PM
Rayo's Avatar
"6L3Z-7A194-A" will work..
Just make sure to use the right filter--->>F6AZ-7A098-A or FT105
The newer filter has an extension tube on it to reach down into that little hump in the pan..
For an even better factory pan with a drain plug, and that little hump..Try the 98-04 E-250 pan--->>F8UZ-7A194-AA
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 3 (permalink) Old 03-19-2014, 08:41 PM Thread Starter
Lafayette's Avatar
Great news , as I have already bought it. The price of the one with the drain plug was nearly double and I was already unsure , so I opted to go this route. Thank you for taking the time to confirm.
