4R70W Shuddering.. I think.. - TCCoA Forums
post #1 of 22 (permalink) Old 07-01-2014, 04:54 PM Thread Starter
13's or Mildly Broken
I'm reasonably sure my 99 P71 has the infamous trans shudder, but I'm hoping for a 2nd opinion here. It's very noticeable between 45 and 65 mph. No CEL or anything that would make me think it's a miss.
And assuming it is trans shudder - a fluid flush and filter change will help it? And am I OK to drive it until I get an afternoon to change the fluid (and find a garage)?
Melon is offline
post #2 of 22 (permalink) Old 07-01-2014, 06:40 PM
Best test is a little tough without a tach, but when you feel it doing what you think is TC shudder, using your other foot and apply just enough brakes to make the TC unlock, but not change your speed or load. With a tach you watch the RPMs to be sure the rise up. If the the shudder goes away, then it is likely the TC. If the shudder doesn't go away, it is an engine issue likely, if not a full blown miss, then the EVR, DPFE, or weak coil that isn't a full blown miss are suspect.
Bangster is offline
post #3 of 22 (permalink) Old 07-01-2014, 07:17 PM Thread Starter
Unfortunately that year CV doesn't have a tach so that will make it difficult.
The DPFE sensor was the other thing I had considered with the reading and searching I did. I tried the brake test for the TC and I don't think it entirely went away. Could I try to just unplug the sensor and see if it helps at highway speeds?
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #4 of 22 (permalink) Old 07-02-2014, 07:02 PM
Has the trans been serviced lately?
If not a filter and about 12 quarts of Mercon v usually helps, that Lube guard shudder fix seems to work well also.
bulldog is offline
post #5 of 22 (permalink) Old 07-02-2014, 09:05 PM Thread Starter
Not that I'm aware of, but I've only had the car a few weeks. I should pull the dipstick and see what it looks/smells like.
I'm still unsure about driving it since I'm not sure what the issue is, but I'm thinking that's what I'll have to do in order to figure out whatever issue the is.
2000 Explorer 5.0
Melon is offline
post #6 of 22 (permalink) Old 07-02-2014, 10:17 PM
nall_one's Avatar
if its brown, flush it with mercV. if its the black death, well... you could still flush it, but it would probably quit shifting tomorrow; do it and hope for the best.
usually the mercV stops the shudder if you catch it right away, if its been driven a long time with the problem then the TC is toast.
trans cooler never hurts either. i usually just go out looking through the local UpullIt for heavy duty trucks with nice tank style coolers and yank one off. just make sure its not all full of metal shavings, from the shrapneled trans that put the truck their in the first place nice cherry red fluid is always a good sign
nall_one is offline
post #7 of 22 (permalink) Old 07-03-2014, 09:15 PM
CrystalPistol's Avatar
When I got my '95 with 52,000 miles in 2009, it had the shudder pretty bad the first time I drove it more than 20 miles. Bad shudder. I guessed it had original fill, so I changed with new filter and 12 quarts Mercon V.
Shudder has never yet repeated, just over 90,000 miles now.
When it was about 67,000 miles I drained the fluid and dropped the pan and did a mild J-mod to it and added an aux trans cooler to the front in the return line. I then filtered the still good Mercon V and reused what I could, I kicked in another couple quarts that covered losses and cooler I guess.
Just this week bought 24 quarts Mercon V and two filter kits to do my '01 mercury (gonna do a mild J-mod too and add a back up plate from Sonnax that's missing) and the '95 Bird again .... both are about due.
CrystalPistol is offline
post #8 of 22 (permalink) Old 07-03-2014, 09:29 PM
With the size and style of cooler his 99 CVPI has, I wouldn't add an another cooler, unless towing 5000 pounds over a mountain pass every day.
Bangster is offline
post #9 of 22 (permalink) Old 07-04-2014, 04:25 PM Thread Starter
Checked the fluid and it doesn't smell or appear burnt, but I'm still considering doing a flush and filter change.
I assume the trans won't just randomly grenade, even if the damage has been done? I can't afford a rebuild at the moment.
Thanks for the responses
2000 Explorer 5.0
Melon is offline
post #10 of 22 (permalink) Old 07-06-2014, 09:06 AM
BUCK's Avatar
Question Cops ____?
I say Plugs & Wires.... or does 99 CV have COPS ____?
BUCK is offline
post #11 of 22 (permalink) Old 07-06-2014, 04:07 PM Thread Starter
It has COPs. And if it was a miss, wouldn't it be noticeable in a certain RPM range, regardless as to which gear the trans is in? It seems like it's only there in 3rd and 4th gears.
2000 Explorer 5.0
Melon is offline
post #12 of 22 (permalink) Old 07-07-2014, 07:51 AM
T6Rocket's Avatar
Shudder occurred for me right after the shift into OD. Sometimes feels like you drove over some rocks.
I would change the fluid ASAP per the tech articles floating around here, do not drive it far like that.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #13 of 22 (permalink) Old 07-07-2014, 10:43 AM
BUCK's Avatar
Lightbulb
Classic indication of Spark Plug miss will be when you are at very low Throttle & it just shifted into 3Rd or OD - So when you are just "putting" around - Hit the OD Off button & miss goes away = Plugs.
BUCK is offline
post #14 of 22 (permalink) Old 07-07-2014, 04:02 PM Thread Starter
That makes sense and that's when I notice it the most. I'll change plugs tomorrow and see if helps.
2000 Explorer 5.0
Melon is offline
post #15 of 22 (permalink) Old 07-08-2014, 05:17 PM Thread Starter
Nope, still the same. Thinking trans flush now.
2000 Explorer 5.0
Melon is offline
post #16 of 22 (permalink) Old 07-14-2014, 06:34 PM
If i'm not mistaken, hitting the OD button on those also unlocks the TCC so it would go away then too. Do the brake pedal test mentione din post #2, I'm willing to bet it is the converter shudder.
1badcat95 is offline
post #17 of 22 (permalink) Old 07-14-2014, 06:46 PM
It should lock back if it disengages, iirc.
Engine braking when you let off means it's locked.
It's been too long since I had a stock transmission program to know for sure.
post #18 of 22 (permalink) Old 07-14-2014, 06:49 PM
Regardless, supposed to change the trans fluid every 21K miles, right? If it's been a while do it anyway. Only use MERCON V.
After chasing down that annoying vibration for a couple months, turned out to be universal joints.
Good luck with your troubleshooting.
Jim3inVirginia is offline
post #19 of 22 (permalink) Old 07-14-2014, 08:41 PM
Moderator & Teksid Whore
guitar maestro's Avatar
you can rent a scanner for a '99. One that can see the "actual slip across TC" parameter. With this parameter you can actually SEE tc shudder in the numbers. 0 means TC is locked, but if it rises and drops with about the same frequency as you feel the physical shudder (which could be anywhere from 5-15Hz IMO, then that means that is it. Otherwise if it "shudders" but the actual_slip_across_tc parameter remains at 0, then the problem is elsewhere.
guitar maestro is offline
post #20 of 22 (permalink) Old 07-15-2014, 05:35 PM
Does that pid work in our SCT setups, GM?
post #21 of 22 (permalink) Old 07-15-2014, 07:45 PM Thread Starter
I did do what was mentioned in post #2, multiple times in fact, and never noticed a change. What threw me off was sometimes it was worse than others. I had a buddy of mine take it for a drive and he's leaning towards suspension over engine or trans. It makes sense to be something loose and/or vibrating so I'll take it to a shop in the next few days and see what they say.
2000 Explorer 5.0
Melon is offline
post #22 of 22 (permalink) Old 09-22-2014, 02:01 PM
Merc V, the J mod and Lube guard fixed mine. Be sure to drain the torque converter and get all the fluid out. Might want to add a trans cooler as well.
88lx50 is offline
