1st to 2nd shift issue - TCCoA Forums
post #1 of 11 (permalink) Old 09-01-2014, 12:15 PM Thread Starter
95tbird1376's Avatar
first its a 95 tbird 4.6 has 4.10 gears , jmod,and exhaust. every once in a while when it goes to shift from 1 to 2 it acts like it hangs up part way between gears. it did this also with the stock 3.08 gears. will do it if in auto or manually shifting at part throttle it usually acts fine. doesnt do it all the time. any ideas what may be causing it???
95tbird1376 is offline
post #2 of 11 (permalink) Old 09-01-2014, 02:24 PM
Is something burning?..
JLangton2's Avatar
Is it a pause, or a shudder?
-Jonathan
The DD:ECOBLEWST:2016 Mustang Ecoboost [email protected]
1995 Thunderbird LX
The "High Mileage Thrasher" 1997 JL 4.6 bird!
generated by sloganizer.net
JLangton2 is offline
post #3 of 11 (permalink) Old 09-01-2014, 03:08 PM Thread Starter
its like you feel it shift but it wont fully engage till you let off
post #4 of 11 (permalink) Old 09-01-2014, 03:13 PM
Sounds like an accumulator spring.
post #5 of 11 (permalink) Old 09-01-2014, 03:35 PM Thread Starter
when i did the jmod i removed the springs when i replaced the pistons
post #6 of 11 (permalink) Old 09-03-2014, 11:21 PM Thread Starter
bump anyone?
post #7 of 11 (permalink) Old 09-04-2014, 05:49 PM
BUCK's Avatar
Angry
Could be a toasted Roller Clutch.
http://forums.tccoa.com/vbpgimage.ph...0&d=1360008776
BUCK is offline
post #8 of 11 (permalink) Old 09-04-2014, 08:16 PM Thread Starter
i have started paying more attention to it the last few days doesnt do it when the trans is cold only after it has gotten hot from driving
post #9 of 11 (permalink) Old 09-04-2014, 10:04 PM
rushtonracing's Avatar
Did this problem occur before the j mod, and/or accumulator piston change?
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #10 of 11 (permalink) Old 09-04-2014, 10:07 PM Thread Starter
after i believe
post #11 of 11 (permalink) Old 09-04-2014, 10:57 PM
If after it leads me to believe something went wrong with the j mod procedure.
If you are confident all the holes in the separator plate were drill in the right location, and to the right size. And all the check balls are there, and in the right place, the separator plate(s) may be warping upon temp. increase causing too high throttle pressure.
I'm inclined to suggest re-torquing the valve body with a known calibrated torque wrench in the proper sequence.
Another is a sticking/leaking accumulator piston. IIRC, you may want to try re-installing the bottom spring.
That's a simple thing to do, hence why I make these suggestions first.
Other things that come to mind not j mod related:
Sticking 1-2 shift valve.
Bad pressure regulator valve/bore. Ever hear any buzzing sound when it's hot?
Sticking/stuck/gummed up clutch drum check ball.
Any runaway rpm's during the shift?
CEL off?
Checking transmission pressures with gauges, and duplicating the complaint, might give clues.
2004 Tahoe 5.3 4x4
