97 LSC Trans questions/problems - TCCoA Forums
post #1 of 13 (permalink) Old 12-26-2014, 01:15 PM Thread Starter
getblown's Avatar
Question 97 LSC Trans questions/problems
I picked up a 97 LSC a few months back for a DD. Silver on Black, true dual upgrade with x pipe and SS mufflers, posi unit and stereo. Im happy with it as a highway cruiser seeing 60miles a day. There are however a few issues.
1. As of 80-82mph, I am locked out of 3rd gear. I mean I can ease up to 80mph with OD turned off at the shifer, OD OFF light works, but as I hit 80mph, the car shifts and turns off my control of OD. It WILL smack OD at WOT. I have to slow down below 80mph before I regain control of OD. A nuisance more than anything really. I don't believe under WOT it should shift to OD nor lock me out of 3rd. Any thoughts?
2. Are the 4R70ws in the LSCs tuned differently on how they react? This transmission doesnt react to WOT downshifts and will lock down in OD at 33mph and stay there until I manually move it or go low enough for it to downshift itself.
3rd and least important... these spring coversion kits, smh. I believe it was a 'suncoast' kit. Are they all crap or does this one especially suck? I enjoy bounding in a water bed, not my car on the highway.
94 Opal LX - 4v, cobra intake, remote3650, 3.73s, Detroit Trutrac. Duals and xpipe.
I need to tune this beast...
The LSC is gone.
getblown is offline
post #2 of 13 (permalink) Old 12-26-2014, 02:03 PM
Most of the spring conversion kits are pretty soft. They are all meant to keep a beater on the road for cheap, and not for performance handling. My advice for that would be to use all T-bird stuff for the conversion. The whole front shock and spring assembly from a tbird will bolt right in, and then for the rear you need something to prevent the spring from moving off the perch. On a buddy's car, I used a few hockey pucks with a hole drilled in the center and then bolted it up to the flat perch on the car and through the hole in the LCA where air spring clipped in. This will let you use any tbird springs you want, either factory or aftermarket.
post #3 of 13 (permalink) Old 02-09-2015, 04:45 PM Thread Starter
getblown's Avatar
Any body?
Also will upshift half way through the rpm range at W0T.
The LSC is gone.
getblown is offline
post #4 of 13 (permalink) Old 02-09-2015, 05:11 PM
I can say that none of the transmission shifting things your reporting are special 97 Mark VIII LSC programming.
To me it sounds like it isn't getting proper input from things like the TPS or the OSS.
I had a really poorly shifting transmission when I bought my 97 Mark VIII, but not like anything you mention.
Issue 1, locked out of D at 80 mph, what does it do instead? OD, second, engine revs freely?
Upshifting at WOT, all gears?
Bangster is offline
post #5 of 13 (permalink) Old 02-09-2015, 05:42 PM
Luxky u. My 94 tbird tranny only locks od at 39-40. I can ride 36 all day itll never kick in unless its cold thrn at 30 it drops in od. Maybe somethings broke
My Mods:
Spectre Custom Air Filter, greasable sway bar brackets - front/rear, custom shifter, plastic dip wheels/center caps original, port/polished throttle body(by me).
Future Mods:
3.73 Gears, 4.6 to 5.0 stroker kit. Supercharger, 100HP NOS shot, Built 4r70w (jmod 450+HP) Trac lok with HD clutches. Fold/split rear seat.
*recover all the leather, freshen it up and clean it.
*paint the whole interior black - 20%
94thunderbird46 is offline
post #6 of 13 (permalink) Old 02-10-2015, 06:12 AM
Darrin's Avatar
As long as the transmission has all functions where everything works, nothing slips and there are no unusual noises then the transmission itself is fine.
Sensor, tune or computer issue. It almost sounds like someone put a special tune in it for best mpg.
D
Darrin is offline
post #7 of 13 (permalink) Old 02-12-2015, 11:11 PM Thread Starter
getblown's Avatar
scenario.
Driving at 65mph, I click the OD button which turns off OD and downshifts the car to 3rd gear. I accelerate, 70, 75, 80mph and just after I pass 80mph, the car upshifts to OD and the dash light goes out. Above 80mph, the OD button does not work.
The trans in my 94LX, if I WOT at 25mph it will jump to 1st gear and take off. This mark just continues to pull in the current gear.
Firmness of shifts, although I like it, are quite firm into every gear. When I purchased the car It had exhaust from downtubes back and a posi unit. It would not suprise me if there was some kind of oddball tune on it.
The LSC is gone.
getblown is offline
post #8 of 13 (permalink) Old 02-13-2015, 06:32 AM
Darrin's Avatar
Ah, you didn't say earlier that you thought it maybe had a different rear end in it. Which is what it sounds like you are saying in your last post. I'm betting it has gears and no tune. That would explain it perfectly.
D
Darrin is offline
post #9 of 13 (permalink) Old 02-13-2015, 07:42 AM
D
That wouldn't explain it turning off OD by itself. I had 3.73s in my 98 MarkVIII with no tune, and if I turned off OD, it would stay off until I hit the 125mph speed limiter.
post #10 of 13 (permalink) Old 02-13-2015, 11:36 AM Thread Starter
getblown's Avatar
D
and the LSC came with 3.27s from the factory, speed vs rpm checks confirm that its stock gearing.
The LSC is gone.
getblown is offline
post #11 of 13 (permalink) Old 02-18-2015, 11:50 PM
Darrin's Avatar
The 98 is a different animal electronically.
I'm not saying that this is definitely the problem, but it actually could explain all of what you described earlier as the computer thinks the car going a lot faster than it actually is based on the input from the OSS which will be turning. The speedometer may have been corrected with a speedo gear but that won't correct the other. The OD cancel button has a speed limited override that's going to change with the rest of the shift schedule because of the gears.
What's the computer code? RKK3 maybe? What size tires are on it?
D
Darrin is offline
post #12 of 13 (permalink) Old 02-18-2015, 11:54 PM
Darrin's Avatar
Didn't see that the gearing was checked to be the same as stock.
Based on the facts that the car shifts early and OD cancel is being overridden it really sounds like the computer thinks the car is going faster than it is.
D
Darrin is offline
post #13 of 13 (permalink) Old 03-10-2015, 06:57 PM Thread Starter
getblown's Avatar
D
Thanks Darrin. I appreciate the thought process from a different angle.
The LSC is gone.
getblown is offline
