Removal of the manual shift lever - TCCoA Forums
post #1 of 4 (permalink) Old 01-18-2015, 02:04 PM Thread Starter
v3r71g0's Avatar
Im having a hard time removing the manual shift lever from my 4r70w.
I have removed the roll pin from the transmission case, and it will slide out partially. I have removed the nut from the end. Is there a spring detent in the roll pin hole or some other retaining pin of sorts that will keep me from completely removing it?
I am trying to swap over a Lokar seletor shaft as per the directions in this article.
http://www.lokar.com/downloads/pdf-i...electshaft.pdf
Do I just neet to pry harder or use some kind of slide hammer to remove it?
1989 Mustang LX. Maxim motorsports grip box equipped.
2000 Crown Victoria Police Interceptor. Bilstein goodness and lowered to the weeds.
v3r71g0 is offline
post #2 of 4 (permalink) Old 01-19-2015, 01:48 AM
Hmm, should pull right out with the roll pin and nut removed, There's no detents or anything else I recall.
post #3 of 4 (permalink) Old 01-19-2015, 12:41 PM Thread Starter
v3r71g0's Avatar
Could it be that the seal may have bound up on the lever or caused it to gall somehow? This is from a 2001 Grand Marquis.
v3r71g0 is offline
post #4 of 4 (permalink) Old 01-21-2015, 06:56 PM
The seal is hard; you want to replace it.
It will come out; use a slide hammer if you have to.
Assuming, of course that you've removed the bolt and rooster comb, lol; you never know these days.
