99 4R70W transmission rebuild - TCCoA Forums
post #1 of 4 (permalink) Old 03-11-2015, 10:35 PM Thread Starter
88grandmarq's Avatar
Send a message via AIM to 88grandmarq Send a message via Yahoo to 88grandmarq
Arrow 99 4R70W transmission rebuild
This transmission started to vibrate and shudder in 3rd and 4th gear. Eventually, the transmission overheated and started dumping fluid out the vent on the top of the case. When the car was parked, all the fluid dumped out all over the parking lot.
This is a low mileage car with 87K on the odometer. The fluid is black, burned and has water in it. With the pan removed there is heavy clutch material on the magnet and about an 1/8" of fluid/water sludge in the bottom of the pan.
The OD band is burned and all the clutches are damaged and de-laminating from water intrusion. The direct clutches are the worst with 60% of the friction material flaked off and burned. To make matters worse the clutch material had piled up in the bottom of the clutch drum which essentially forced the clutch to be engaged all the time.
The valve body separator plate is rusted from water contamination. The pressure regulator valve has radial scoring all the way around with one shiny spot from wear.
During the process of cleaning parts, I found the direct clutch piston was cracked at the check valve. Good thing for spare parts.
I rebuild AOD/AODE/4R70W/4R75E transmissions....Check out my Facebook page: https://www.facebook.com/pages/North...48414635312478
88grandmarq is offline
post #2 of 4 (permalink) Old 03-12-2015, 05:06 AM
Where'd the water come from? Cracked radiator heat exchanger, or was it submerged at some point?
post #3 of 4 (permalink) Old 03-12-2015, 09:47 AM Thread Starter
Transmission dipstick wasnt fully seated, water drained off the wiper cowl and got into the transmission filler tube.
post #4 of 4 (permalink) Old 03-13-2015, 09:59 PM
decipha's Avatar
that sucks man
water and trans dont mix
supercoupin'
www.EFIDynoTuning.com
decipha is offline
