4R70 valvebody rebuild - TCCoA Forums
post #1 of 4 (permalink) Old 05-03-2015, 11:08 PM Thread Starter
88grandmarq's Avatar
Send a message via AIM to 88grandmarq Send a message via Yahoo to 88grandmarq
Arrow 4R70 valvebody rebuild
Another 4R70W valve body build, this time for a 2003 CVPI.
The owner wanted a Jmod done to go along with his new Tuner.
He shipped a good Used valve body to me, which I completely stripped, cleaned and inspected. It was the cleanest valve body I have seen in a long time. The stock pressure regulator valve had no wear, but the boost valve and OD regulator shuttle valves were pretty worn.
I assembled the valve body with the stock pressure regulator valve, new valves from Sonnax and a new "Tuff" plate (separator plate) from Superior.
The new separator plate was drilled to Jmod spec:
hole 1 = .161"
hole 2 = .1015"
hole 3 = .180"
hole 4&5 = .113"
hole 6 = .161"
hole 7 = .089
hole 8 = not used in this application
hole 9&11 = .125"
hole 10 = .089"
The valve body was reassembled with new gaskets and the bolts torqued to 100 in lbs
I rebuild AOD/AODE/4R70W/4R75E transmissions....Check out my Facebook page: https://www.facebook.com/pages/North...48414635312478
88grandmarq is offline
post #2 of 4 (permalink) Old 05-04-2015, 06:33 AM
Nice. So how'd it work once reinstalled? Was the customer happy?
I had to stop and think for a sec about what a CVPI was ... but I figured it out ...
post #3 of 4 (permalink) Old 05-04-2015, 07:33 PM Thread Starter
Valve body shipped to the customer last week, no word on the Install yet.
I assume it will work well, I have used this method on several other transmissions and it always shifts well.
post #4 of 4 (permalink) Old 05-05-2015, 08:10 AM Thread Starter
Nice. So how'd it work once re-installed? Was the customer happy?
CVPI = Crown Vic Police Interceptor
