Tail shaft extension - TCCoA Forums
post #1 of 3 (permalink) Old 08-02-2015, 08:10 AM Thread Starter
1995 cougar xr7's Avatar
I got a new tail shaft extension housing mine was leaking and flung tranny fluid all over the bottom of the car. One of the top bolts snapped off inside the transmission. I drilled the bolt and used an ez out. The ez out snapped off inside the bolt. I drilled a new hole above it and tapped it and then oblongned the hole on the housing. It will be awhile before I can drive the car so the rvt should be set up pretty good so I hope it don't leak. What a ***** that was. I was thinking a simple change out .
1995 cougar xr7 is offline
post #2 of 3 (permalink) Old 08-02-2015, 09:25 AM
I normally have good luck with drilling out bolts. My EZ Out experiences seem to mirror yours though. Which is frustrating since I know other people use them all the time.
97CatMan is offline
post #3 of 3 (permalink) Old 08-03-2015, 11:47 AM
Rayo's Avatar
It's pretty common for the bolts holding the Extension Housing to break off in the transmission case..
You're near the ocean so that doesn't help..I don't know what's worse driving on salty winter roads, or being near the salty ocean..
Either way the salt will oxidize the bolt threads, and make it difficult to remove the fastener..
The last time I had to remove a broken bolt that was supposed to hold the Extension Housing on..I used Cobalt drill bits..
Basically starting with a smaller bit, and progressively moving up in size..Then I used a tap to thread the hole once it was drilled out large enough..
I was able to use all of the stock size fasteners by doing it this way..
If you ever have to drill out a grade 8 bolt I suggest starting with tungsten carbide..The cobalt drill bits tend to walk more in the grade 8 material..
In hindsight I should have used grade 8 studs, and 12 point nuts to reattach the Extension Housing..
With the studs all you're removing is a nut..That's easier to deal with than a steel bolt in an aluminum housing..
1991 Ford Thunderbird Sport
Rayo is offline
