How to remove 4r70W shifter cable at trans? - TCCoA Forums
post #1 of 1 (permalink) Old 10-07-2015, 05:02 PM Thread Starter
Question How to remove 4r70W shifter cable at trans?
How do I remove the shifter cable at the transmission shift lever on a 1997 Tbird with 4.6 and automatic?
I found this in one of the TCCoA forums but after I removed the nut, the stud won't come out of the shift lever.
" remove the 13mm nut on the ball of the shift cable, remove the 2 10mm bolts holding the cable bracket to the trans case (this enables you to preserve the handle/indicator alignment) "
BlacknTan is offline
