Transmission spring question - TCCoA Forums
post #1 of 10 (permalink) Old 10-07-2015, 05:25 PM Thread Starter
TwoHaggard's Avatar
This is on my beeter bird I do not want to jmod this one, I jmodded mine so long ago I forget some of this stuff. I'm just doing a flush on the beeter car and pulled this apart and noticed the spring was broke.
Can I just leave it out? If so what all do I have to put back in? Thanks!
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 10 (permalink) Old 10-07-2015, 05:56 PM
That's the ... 1-2 lower spring? Leaving out the bottom 1-2 piston spring is an optional part of the J-mod to firm up the shifts. If you aren't drilling the separator plate, you shouldn't experience a terribly firm shift, one suitable enough for DD IMO.
post #3 of 10 (permalink) Old 10-07-2015, 07:05 PM Thread Starter
TwoHaggard's Avatar
This was the only spring in this one... I could careless how this beeter shifts I just wanna make sure it's ok to leave out without doing the jmod. do I have to put anything back in is what I'm asking?
post #4 of 10 (permalink) Old 10-07-2015, 07:07 PM
Nope, it'll be fine.
post #5 of 10 (permalink) Old 10-07-2015, 10:12 PM
That style accumulator piston is problematic. The O ring wears, the piston starts wearing the bore, it gets stuck in crooked. I had a pretty scored up bore, a 1-2 shift that was obnoxious and inconsistent, in my 97 Cougar. The newer style piston sealed just fine.
Personally I would replace it with the steel/bonded rubber one and the cheap upper spring that everyone includes with their JMod kit. I have 3 or 4 of them around as I leave out all springs in my cars.
Bangster is offline
post #6 of 10 (permalink) Old 10-08-2015, 05:44 AM Thread Starter
TwoHaggard's Avatar
I can leave the spring and piston and snap ring off tho If I choose right ?
post #7 of 10 (permalink) Old 10-08-2015, 06:10 AM
Piston, snap ring and cover are all required. Only the spring is optional.
post #8 of 10 (permalink) Old 10-08-2015, 07:29 AM Thread Starter
TwoHaggard's Avatar
Ok great thanks
post #9 of 10 (permalink) Old 10-15-2015, 09:51 AM
BUCK's Avatar
Thumbs down
IMO throwing away that ancient 1-2 Accumulator Piston is required TOO for the "new style" (that aint even new anymore) ... why risk trashing even a beater Tranny over a few bucks~?
BUCK is offline
post #10 of 10 (permalink) Old 10-15-2015, 10:47 AM Thread Starter
TwoHaggard's Avatar
To late, did not put the spring in but put it back together and shifts great now, fluid was never changed.
