Few 4R questions - TCCoA Forums
post #1 of 5 (permalink) Old 03-31-2016, 04:31 PM Thread Starter
JoeyICU's Avatar
Few 4R questions
So my 9 4r has a TC shudder, so I think I would like to do a rebuilt or used transmission, a new OEM TC (oem mark 8 or marauder). I have found locally a 97 mark 8 4r, or a 2000 4r. The 97 mark trans has 90k. the 2000 has unknown. Both units are 200. I was curious what might be a better choice trans wise. Also I can not seem to find any information on repining the harness for the 2000 trans.
JoeyICU is offline
post #2 of 5 (permalink) Old 03-31-2016, 05:49 PM
The 2000 trans is a better unit. It has the stronger one-way clutch, and an improved case and valve body. Even the 97 trans is a large improvement over your stock one though. As for re-pinning, the 97 and down have one layout, and the 98 up have another, so repining for the 2000 trans is exactly the same as for the 98 trans. As for the torque converter, a higher stall will help the car move out a little better, so I would suggest an aftermarket one with a 3200-3500 stall speed. Also keep in mind for the new converter, you will need to replace your flexplate because the stock converter is a 12", and the better 11" ones have a different bolt pattern for the torque converter.
post #3 of 5 (permalink) Old 03-31-2016, 06:00 PM Thread Starter
JoeyICU's Avatar
Ya I'm going mark 8 TC, they stall around 3000. I know they are different I am looking for any sort of right up or information on the differences. I am leaning towards the 2000 trans, though the unknown mileage worries me a little.
JoeyICU is offline
post #4 of 5 (permalink) Old 03-31-2016, 06:58 PM
Yeah, unknown mileage would have me worried too. Why is the mileage unknown, or is that unknown too? Is there any history on it, like what it came out of, or whether the car was wrecked or a mechanical failure or anything like that? What are your ultimate plans for the car? If you aren't looking to make much more power than stock, then the 97 MarkVIII trans would probably be fine, and it may be a safer bet than something that potentially could have over 200K miles on it. Personally, if I was in your shoes, I would probably pass on both of those and look for a low mileage 99-03 trans, and maybe pay a little more for it, but know that you won't have to worry about it ever again.
post #5 of 5 (permalink) Old 03-31-2016, 07:43 PM Thread Starter
JoeyICU's Avatar
Ya I may do the Jmod and some other little tinkers, and run the 97 trans. I didn't ask about the unknowns of the 200 trans, the lady I talked to seemed annoyed that I was calling about them being for sale. I would like the car to hit in the 300whp range. Getting this trans has me with 2 transmissions, so I would not sweat blowing one up. We shall see. I have to ponder it a bit. Maybe I can bring her down price wise.
JoeyICU is offline
