end play clearance? - TCCoA Forums
post #1 of 2 (permalink) Old 07-12-2016, 12:50 PM Thread Starter
end play clearance?
Hi can I check end play with a feeler gauge to determine the right pump thrust washer or will I need a dial or depth gauge? I don't have the money to buy the one the service manual says to use since this will probably be my only time using it and only transmission rebuild I'll do its for and aode btw thanks in advance!
godfearingman is offline
post #2 of 2 (permalink) Old 08-05-2016, 07:05 AM
Darrin's Avatar
Without the correct tool or an H-Gauge then you aren't going to get it.
D
Darrin is offline
