Question about the B&M trans cooler - TCCoA Forums
post #1 of 4 (permalink) Old 08-19-2016, 06:16 PM Thread Starter
Mr.Thunderbird's Avatar
Are the B&M trans coolers supposed to be used alone or as an additional aid to radiator cooling? I noticed my mechanic hooked mine up so it cools the fluid after it comes out of the radiator.
Mr.Thunderbird
Mr.Thunderbird is offline
post #2 of 4 (permalink) Old 08-19-2016, 07:09 PM
Depends on who you're talking to I guess.
Some people get larger coolers and bypass the radiator all together, others (myself included) use it for additional cooling tied in after the radiator.
post #3 of 4 (permalink) Old 08-19-2016, 07:36 PM
Either way is an improvement over stock. A larger cooler will be sufficient to be run by itself, and that would likely keep the fluid the coolest, since the radiator is running around 200 degrees when the engine is warmed up.
post #4 of 4 (permalink) Old 08-19-2016, 07:39 PM
In cold climates some prefer to run it with the radiator so it warms up quicker, I liked running mine by itself since there's no risk for contamination if there's an internal leak, plus I was able to route the lines cleaner
