High Revs - TCCoA Forums
 1Likes
  • 1 Post By MadMikeyL
post #1 of 5 (permalink) Old 12-29-2016, 07:54 PM Thread Starter
driller's Avatar
High Revs
How high of rpms can a 'built' 4R70W take? I forget most of the details but it was a purpose built race transmission complete with rear lube mod. The car has the huge tranny cooler and a 4400 stall Circle D lockup up converter.
After the recent motor overhaul, the datalogs from the last track outings before the winter set in suggested I will need to up the shift points and change from 4.30s in the differential to 4.88s to make the most out of it. Currently I have both shift points set at 7,000 in the software. Datalogs show the actual 1-2 shift point around 7,500 and the actual 2-3 shift point at 7,100-7,200 The 1-2 seems to be close to optimum but the 2-3 is definitely too early as it drops the revs too low (5,100-5,200) when it shifts to 3rd.
The datalogs and dyno math tells me I need to be pushing 8,000 rpms on the 1-2 shift and around 7,750 on the 2-3 shift. I figure when spring comes I'll take it to a test and tune and sneak the shift points up around 250 each increment until it seems to run out of breath or the slips say it is slower or...
driller is offline
post #2 of 5 (permalink) Old 12-29-2016, 08:52 PM
I have heard that at extreme RPMs the rotation can remove the working fluid from the clutches, but I find that hard to believe; it's pretty constrained.
Oscar plans to operate upwards of 7 grand; idk what his mods are.
I'm sure they're expensive, and have a coating...
post #3 of 5 (permalink) Old 12-29-2016, 09:51 PM
Yeah, a coating of dust!
Woodman likes this.
post #4 of 5 (permalink) Old 12-29-2016, 10:31 PM
post #5 of 5 (permalink) Old 12-30-2016, 06:51 AM
JP. My redline is at 7K I've never had a problem with the transmission handling that; I'm not sure where Rob's set my shift points but they're probably comperable to what you've outlined above. I would suggest calling Rob to discuss your plans.
I was thinking the same thing. I'm glad you said it first.
