Transmission Temp Guage - TCCoA Forums
 2Likes
  • 1 Post By Mr.Thunderbird
  • 1 Post By racecougar
post #1 of 3 (permalink) Old 04-07-2017, 02:20 PM Thread Starter
Mr.Thunderbird's Avatar
I have the trans rebuilt and working fine. I am thinking of adding a gauge to monitor the temperature. A couple of questions.
Is there a place that is ready to install the temperature sensor on the trans itself?
Also, what it the normal temp for one of the transmission to run??
Woodman likes this.
Mr.Thunderbird
Mr.Thunderbird is offline
post #2 of 3 (permalink) Old 04-07-2017, 09:25 PM
A cheap/easy method is to add a drain plug to the pan, but replace the plug with the temp sender.
https://www.summitracing.com/parts/s...bwExoCkgfw_wcB
Fluid temps ~150-ish F are a happy spot.
Woodman likes this.
post #3 of 3 (permalink) Old 04-08-2017, 09:45 AM
S4gunn's Avatar
When I had an automatic, I plumbed one in at the return line from the transmission cooler using a Tee fitting.
NOTE: even though most sensors are "one wire", if your T fitting where the transmission sender goes in is ungrounded (like it's not on a hard line but between two rubber hose segments), you will need to run a second wire to the base of the sender as a ground.
http://goo.gl/csaet4
S4gunn is offline
