No OD and slipping 3rd. - TCCoA Forums
post #1 of 2 (permalink) Old 10-30-2017, 03:34 PM Thread Starter
maxxaddict's Avatar
Exclamation No OD and slipping 3rd.
Okay, I have a 97 4R70W transmission installed in a 95 Cougar.
Trans had recent JMOD, fluids were clear when drained originally, replaced with Mobil 1 Mercon V/Dextron multi blend ATF. Fluid levels are good.
New reman torque converter from MK8.
New MLPS
New TC Solenoid
New filter
JMOD was done a few months ago (mild spec), in preparation for install. Just got everything installed last night and took the car out for a shakedown run. Noticed no OD on highway and the trans wouldn't shift back down to 3rd.
If I turn the OD off, the car will operate normally through 1-2, 2-3 shifts, and shift down normally as well.
If I engage the OD, the car will operate normally 1-2, 2-3 then no OD and when slowing down, does not re-engage 3rd. I have to bump it down to 2nd manually to get it to grab a gear.
Just wondering if there is a good place to start without tearing everything apart again.
I'm assuming it's either the band or the shift solenoid.
Thanks in advance.
95 Cougar 4.6
maxxaddict is offline
post #2 of 2 (permalink) Old 10-31-2017, 07:00 AM
Darrin's Avatar
The only way it could be the solenoids is if there is a loose enough connection to allow SS1 to work in 1st and SS2 to work in 3rd, but not enough juice to allow both in 4th.
Do you know if it worked previously? If it did then I'd first check all the connections everywhere and then look at the gaskets and make sure nothing is folded over and leaking.
If you don't know, do you know if the snap ring for the OD servo was still in one piece? Inside the valve body I would check the 3-4 shift valve and also particularly the OD servo regulator valve to make sure everything is clean and moves freely.
D
Darrin is offline
