trans problem clicking clunking noise - TCCoA Forums
post #1 of 6 (permalink) Old 03-29-2018, 07:16 AM Thread Starter
It is nice
Question trans problem clicking clunking noise
So my trans has a clicking/clunking problem during acceleration. Would this be the MLPS? Thanks.
91CougarLS is offline
post #2 of 6 (permalink) Old 03-29-2018, 10:15 AM
I would rule out the trans mount first then dig deeper.
96 Thunderbird LX 3.8L
Fishing when I'm not driving
Advice welcomed
jt96NY is offline
post #3 of 6 (permalink) Old 03-29-2018, 10:35 AM Thread Starter
It is nice
Transmission mount was replaced not too long ago and engine mounts.
post #4 of 6 (permalink) Old 03-29-2018, 12:55 PM
Urambo Tauro's Avatar
I don't want to lead you on a wild goose chase here, but you need to be sure.
I made the mistake once of torquing my old trans mount (after a clutch change) without cleaning the threads first. The torque wrench clicked, but the car made a clunking noise afterward because the dirty threads had tightened up before the bolts had a chance to fully seat.
Urambo Tauro is offline
post #5 of 6 (permalink) Old 03-29-2018, 01:46 PM Thread Starter
It is nice
Thanks. Turns out the clicking was the spark plugs misfiring causing the clicking and thumping. The trans still shudders a tiny bit but not nearly as much as before. The bad news is my valve cover and intake manifold gaskets are both leaking on the driver side and had a bit in the spark plug holes so I will have to fix those also.
post #6 of 6 (permalink) Old 03-29-2018, 02:55 PM
All of those are normal problems, at this point.
Time for a PI intake!
