4r70w J-Mod questions - TCCoA Forums
 1Likes
  • 1 Post By Grog6
post #1 of 3 (permalink) Old 08-03-2018, 09:43 PM Thread Starter
white lincoln's Avatar
Hi all,
In rebuilding my valve body, two questions came up that I can't find an answer for:
1) The two springs for the Capacity Modulator Valve and the low servo modulator valve are different, but I can't find in the service manual or the documentation which spring goes first.
(see pic below from https://www.tccoa.com/articles/mn12-...w_rebuild.html and the pic from my springs below).
One spring is orange/red(?) and the other spring is black. The orange spring is shorter than the black spring.
2) In the 4r70w document mentioned above in the TCCOA forums, the author mentions drilling a hole into the boost sleeve port to keep the torque converter charged. I do not see this in either of the other articles or the Baumen Engineering document I have for the AOD. Is this necessary or required for the J-Mod? (see pic below).
Any comments would be appreciated.
1995 Lincoln Town Car Signature Series - 180k!
1994 Mercoury Cougar XR7 - still going....
1988 Lincoln Mark VII LSC - SOLD!
I've had too many other cars to mention...
white lincoln is offline
post #2 of 3 (permalink) Old 08-03-2018, 11:53 PM
Dude, how far are you into this transmission?
I would disassemble the one you have, remove the tail shaft, and go buy a 2002 4r70W to rebuild.
Replace all the SEALS, use your tail shaft, and add the upgrade parts for that tranny; Sonnax is your friend.
I used a "Super Tuff Plate" on the 2002 tranny, as a well as the Sonnax Plate.
https://www.explorerforum.com/forums...-diary.128800/
The original solenoids are available from PATC, they are good guys.
Old Connector for New Tranny: To match your eec, things have to change)
https://transmissioncenter.net/shop/...e-4r70w-92-97/
Add your solenoids into the new one; i think it's the TCC, but Search.
There are several reasons NOT to rebuild a 94-95 trammy.
If you do as above, it will plug and play.
Third Ford Burden likes this.
post #3 of 3 (permalink) Old 08-04-2018, 09:10 AM Thread Starter
I am just doing the valve body. Re-building the tranny would be a nice project, but the wife needs her car before next year. :P
I think from the pic from the link above, the orange spring goes in first.
Thanks!
