Oil cooler line woes - TCCoA Forums
 1Likes
  • 1 Post By theterminator93
post #1 of 3 (permalink) Old 10-23-2018, 03:30 PM Thread Starter
WMC
WMC's Avatar
Hey everyone.. So I'm finally removing the transmission.. Was trying to remove the oil cooler lines... top one came out good bottom one twisted.. Where can I get a new line? or do I have to make one? thanks
WMC is offline
post #2 of 3 (permalink) Old 10-23-2018, 05:47 PM
I don't think you can get them new anymore. I would just give it a fresh cut and flare the end slightly, and slip a length of transmission cooler hose (usually good to 300 PSI) over the end. Then you can get a barbed fitting for the other end.
Had a similar setup on my T-bird for years before I went to a different cooler setup.
Turboedmav likes this.
post #3 of 3 (permalink) Old 10-24-2018, 11:52 AM
Yeah... I don't think the time spent trying to get a new one (or make a new one) is worth it. Just cut it where it was bent and add a length of rubber hose, needless to say, it must be appropriately rated for use with high pressure, hot oils. Any hydraulic fittings store can supply the hose and hardware.
Turboedmav is offline
