97 Mark VIII P1747 Code - TCCoA Forums
post #1 of 2 (permalink) Old 03-21-2019, 07:37 PM Thread Starter
So – I have a nagging P1747 code and rough shifting – happened all of a sudden. Dropped the pan and changed out the EPC Sensor and replaced all the fluid (Mercon V). While waiting for the new EPC to arrive, checked the original sensor and checked out within spec – as did the new replacement. Went ahead and installed new sensor (cheaper than the fluid) and once back together immediately got another P1747 code. What to check next and where?
Help!
fabspec is offline
post #2 of 2 (permalink) Old 03-21-2019, 08:54 PM
That's the code for a shorted epc.
If the epc was good, I'd unplug the connector and use an ohmmeter to see which side is shorted, the tranny or the wiring.
It will be shorted to ground, most likely, or to the +V power wire. I don't think the eec can see a short to +, but I'm not sure.
The car side of the wiring is connected to a driver on the eec; so only use a digital ohmmeter, and try not to kill the eec.
Metal from the tranny wear can get into the wiring circuit board, shorting stuff out.
Similar Threads
97 Mark VIII accumulator(s) style 5/97 Bangster 4R70W Transmissions 5 01-22-2013 12:03 PM
P1747 - What Next??? grumpy_steven 4R70W Transmissions 25 08-06-2011 08:41 PM
97-98 Mark VIII Front Clip on a 96 Mark!! AdicusDio Exterior 7 12-28-2009 07:58 PM
P1747 smokymance 4R70W Transmissions 25 05-09-2008 10:30 AM
Help installing 98 Mark VIII tranny into 94 Mark VIII biggyzzz Drive Train 1 08-14-2002 09:10 AM
